question about header install
Old Dec 1, 2006 | 03:27 PM
nomoreavril's Avatar
how the hell do you get to all the bolts? do i need to buy some kind of tiny torque wrench of whatever its called? i just dont see how that would work, cuz its small you still need leverage. the ones towards the top above the header are easy to get to , but the ones like under and inbetween tubes??? they look impossible!
and also, anyone know the size of wrench i need to get out the 02 sensor? or is there some type of special tool needed.
p.s. yeah those downpipe bolts? insane!
Old Dec 1, 2006 | 03:39 PM
Trag's Avatar
For the O2, I used an adjustable wrench but first disconnect the battery, then unplug the O2 sensor so you dont trigger a CEL. As for the bolts between the tubes on the header. I used a swivel joint extension on my air rachet. Did this to all my past cars. You might have to go back under there in a week to check the bolts are tight again. Heated metal expands and what not. good luck.
Old Dec 1, 2006 | 07:51 PM
rally's Avatar
FYI A torque wrench is for installing bolts that need to be torqued for insuring a connection.
Your best bet is to have it done professionally. But if you still want to do it yourself buy BG Penetrating Oil from Auto Zone or local Parts Store, And get access to air tools.
Old Dec 2, 2006 | 12:11 AM
a shop said they could do it for 250 bucks.. and i have another shop that can do the welding and stuff for less than 100 but i gotta attach it to the block..
Old Dec 2, 2006 | 12:17 AM
The_Blur's Avatar
You should take pictures and make this into a How-To.
Old Dec 2, 2006 | 01:19 AM
i was thinking about it, because i was hoping i would find a how-to someone else made but to no avail lol
Old Dec 2, 2006 | 01:21 AM
HackAbuse's Avatar
I did my manifold in 4 hours by myself with nothin but hand tools
its really straightforward
Old Dec 2, 2006 | 01:26 AM
D4u2s0t's Avatar
for the hard to reach bolts, what me and my father did was put the wrench on, made sure it was secure, and used the wooden handle from a sledgehammer for leverage... we tried for over an hour to get one tight ass bolt off, wouldn't budge... used the sledgehamer trick and it working with no effort at all..
Old Dec 2, 2006 | 01:29 AM
the pacesetter has to be welded though
Old Dec 2, 2006 | 01:39 AM
HackAbuse's Avatar
bolt it on, then drive to the nearest muffler shop
seriously, it cant be much louder than my exhaust is, as long as you dont get on it, and shift below 2200RPM, it wont be incredibly loud
Old Dec 2, 2006 | 01:40 AM
memphisr24's Avatar
Torque wrench...and a lift helped me out but I work at a gas station so I have access to a lift haha u suckers without lifts!.....but til this day, my header still leaks it's been about 3-4 months now
Old Dec 2, 2006 | 01:57 AM
rally's Avatar
You didnt use a torque wrench to take your bolts out did you? Thats a big NO NO.
And I have access to roughly...20 lifts, heated garage, damn near any tool I would want. So I agree haha to the suckers
Old Dec 2, 2006 | 02:23 AM
amomentsnotice's Avatar
i had the same prob.... i was going insane.
until i discovered my best friend at the time: wd40
Old Dec 2, 2006 | 02:29 AM
yellowcobaltss05's Avatar
if your not comfortable doing it then have a shop do it. I just had my pacesetter welded to a custom downpipe with no cat and it sounds like lighting lol. The easiest way to get the bolts is to have a lift to get under the car. Half of them are reachable from the engine compartment and half underneath the car. Also if you buy the pacesetter header for your car, as long as it is the same as mine, the shop (Exhaust Depot) i went to is starting to make stock downpipes(2.5") and a custom pacesetter header w/ downpipe setup that fits perfectly. I will have pics in a couple days if you want me to show you
Old Dec 2, 2006 | 03:00 AM
it is? why is that
Old Dec 2, 2006 | 04:45 AM
xspyder85x's Avatar
the torque wrench is not made to loosen bolts. it can screw it up, its only made to tighten things.
Old Dec 2, 2006 | 10:49 AM
06Pursuit's Avatar
i have a set of ramp that i used to install my cat-back, i was hoping to use it to install the header too. Is there any benefit of running no cat on the 2.2? I can understand running a test pipe on the SS/SC but what about the 2.2? I was thinking of having one made so that I can run it at the track but i don't think it will benifit me too much. The cat is preaty high flowing from factory
Old Dec 2, 2006 | 11:17 AM
it might help you just a smidge unless you had like a bunch of mods maybe.
what should i use to take off the bolts then i cant think of anything
Old Dec 2, 2006 | 12:09 PM
rally's Avatar
A socket wrench, an air impact gun, an air ratchet, a breaker bar.
Only use a torque wrench to install bolts, if you use it do "break" the seal on bolts you'll f*** up the torque wrench, probly to the point where you will need to buy a new one.
Old Dec 2, 2006 | 12:20 PM
oh, a socket wrench thats what i used sorry, i dont know all the names, i thought they were the same thing. i also thought ratchet = socket wrench?
Old Dec 2, 2006 | 12:26 PM
rally's Avatar
Yes a ratchet is a socket wrench, just depends on who you talk to
Old Dec 2, 2006 | 12:32 PM
06Pursuit's Avatar
any more info on the cat delete for the 2.2?
Old Dec 5, 2006 | 08:18 PM
06cobaltls's Avatar
i did my entire exhaust swap from header to muffler tip within 2 hours, to get the bolts on the manifold you need a swivle socket adapter, and we used a lift as well, got the downpipe bolts off with a 4 foot socket extension, he pulled it out i hadnt seen it before i was like holy ****, he paid over 70 bucks for it, when i take it back off the car i will try and do a pic tutorial of everything
brandon04
Oct 21, 2015 07:04 AM
dennis69
Oct 20, 2015 07:39 AM
justinchinn
Oct 2, 2015 12:18 PM
z28addiction
Sep 28, 2015 12:03 AM
Bohb
Sep 27, 2015 09:11 PM
