question about my 2.2 head
Old Mar 24, 2007 | 09:17 PM
BIG-DAVE's Avatar
ok im look to do some head work a little at a time but if i get valves and retaines and springs and a 3 or 5 angle valve job .etc.... do i have to change my cams or cam gears .............................. or if i do cams and gear s what else do i have to change or could i use stock valves etc...... i have a 2.2 cobalt thanks .............
Old Mar 24, 2007 | 09:22 PM
Jackalope's Avatar
5 angle valve jobs are a waste of money IMO just stick with 3. I've seen bench flow results from them in person and the cost involved does not justify the small gains. Since your planning on doing this I'd recomend having the shop port the intake and exhaust runners and install bigger valves. The increased valve size is almost like getting new cams. Heres why, the cams allow more air flow, so do the bigger valves. TA DA! That simple. Cams are expensive! Upwards of $400 for the least expensive I've seen.
I think you'd be better suited with the port job and the valves for the money.
Old Mar 24, 2007 | 09:39 PM
BIG-DAVE's Avatar
should i go with springs and retainers or just valves and a port and polished and bigger valves and do i need a tune ???
Old Mar 26, 2007 | 10:47 AM
Jackalope's Avatar
IDK about the tune part sorry as I'm mostly old school hot rods and such, but the basics still work! Yur stock springs should be fine cause your not adding any lift from a bigger cam, your keepers, locks, retainers, or whatever else you may call them I'd recomend getting thee best you can find! It sucks ass to drop a valve cause of a bad keeper, trust me I know! I'd say port and polish, bigger valves, and better keepers are an awesome start that will support future mods.
brandon04
Oct 21, 2015 07:04 AM
HEATON
Oct 16, 2015 07:21 PM
Dylan Johnson
Sep 30, 2015 08:57 AM
Sep 28, 2015 12:51 PM
