Question about tuning
Old Sep 11, 2008 | 11:56 PM
YzRider452's Avatar
Im considering ordering the Ls2edit tuning software, but i have a few questions about it. Right now i have the p0420 code which is making my car run like ****, because of the header/ downpipe with the highflow cat. Does disabling that code make the car run better? Or just get rid of the light? I am fully bolted, and i just want some tuning software to take advantage of my mods, but with this code, my car just isnt running right.
Old Sep 11, 2008 | 11:59 PM
Jn2's Avatar
Jn2
disabling code will make it so the CEL goes off, disa ling codes dont fix the problem, rather just hide it
Old Sep 12, 2008 | 12:04 AM
YzRider452's Avatar
Right, so will the car still perform like ****, If i desconnect the battery the car runs good til to code pops up.
Old Sep 12, 2008 | 10:48 PM
YzRider452's Avatar
Anybody?
Old Sep 14, 2008 | 03:23 PM
Maven's Avatar
The car isnt running bad because of the code, its setting the code because its running bad.
The P0420 has NO EFFECT on the way your car runs, the computer doesnt make any adjustment or take any action when a P0420 sets.
A P0420(as you probably know) is a code for catalytic converter low efficiency, it means the computer has detected the cat cant store enough oxygen to do its job. A cause of cat failure is excessively rich running, you running rich?
Disabling the code with LS2E will stop you from setting the MIL, but it wont/cant solve the problem that caused your cat to fail.
If your car runs good after you disconnect the battery then the most likely cause is a massive rich or lean condition. When you disconnect the battery you clear the fuel trims and the car runs on the standard maps until it has had enough time to monitor and readjust to what it feels is a safe fuel trim. You need to fix your issue, not cover it up.
Old Sep 14, 2008 | 03:25 PM
Jn2's Avatar
Jn2
exactly what i said, it just hides it, it dont fix it, the CEL is just telling what is wrong, but its not causing the problem, deleting it wont make ur cat good
Old Sep 14, 2008 | 04:25 PM
Maven's Avatar
I know JN2, but the important part of my post was that the P0420 also isnt why the car is running bad. Some codes, once set do force the computer to adjust engine performance, etc.....however the P0420 is not one of these "active" type codes, its just there.
Old Sep 14, 2008 | 06:37 PM
YzRider452's Avatar
So what would i do to fix this?
Old Sep 14, 2008 | 06:41 PM
ecotecon18s's Avatar
retune your car...lean it out...or richen...whichever
Old Sep 14, 2008 | 06:42 PM
YzRider452's Avatar
Thats what i thought thanks man.
Supercharged06SS
Dec 11, 2022 04:47 PM
brandon04
Oct 21, 2015 07:04 AM
no_ss
Oct 18, 2015 11:58 PM
Oct 13, 2015 09:32 PM
Extremespeed
Sep 29, 2015 04:34 AM
