Question for those with a 2.4 tb
Old Oct 10, 2013 | 08:44 PM
BLKLS's Avatar
How much low end did you loose? Did you gain much in the mid range? If I install and tune for one and I don't like it do I have to retune to install a stock tb?
I would like to do this but if I loose to much low end I don't wanna do it.
Old Oct 10, 2013 | 11:47 PM
BankerBalt's Avatar
You wont notice a difference
Old Oct 11, 2013 | 05:43 AM
BlueBalt1113's Avatar
Yea you won't notice a difference except for the tune if I were you save the time and add the 2.4 intake mani with the tb and do full exhaust and then you will notice.
Old Oct 11, 2013 | 06:53 AM
BLKLS's Avatar
Already have intake intake mani and full exhaust. So your your saying the tb swap makes no difference....
Old Oct 11, 2013 | 11:09 AM
Jesse's Avatar
If you tune for the 2.4 properly you shouldn't notice a low end loss. I have 2.4 IM/TB and a full 2.5" exhaust (catted). I cannot tune properly until I get a wideband but my low end is still acceptable and WAY better than stock. The mid range and high end are beasts compared to stock. Will you tune it yourself or take it to someone else?
Old Oct 11, 2013 | 01:20 PM
dsmnutz's Avatar
What are you using for the tune?
Old Oct 11, 2013 | 06:03 PM
Jesse's Avatar
HP tuner. I know I can tune the part throttle using stft+ltft but I just don't have the time to learn the pid right now with two jobs. But here's a listof stuff I DID tune:
Max out speed limiters
Adjust ETC scalar to 2.4 TB
Disable throttle opening delay
Add 2* timing to each octane table and adjust for any (non existent) knock retard
Adjust WOT 3-4 shift to 116mph
Increase trans pressure across every shift
Reduce shift times very slightly
Disable rear O2 sensor code
Set PE delay to 200rpm
Old Oct 11, 2013 | 06:24 PM
night_throne's Avatar
lsj tb or go home
Old Oct 11, 2013 | 06:56 PM
BLKLS's Avatar
Can't tune it my self it's an 06
Originally Posted by night_throne
lsj tb or go home
Wouldn't an lsj be overkill on stock cams?
Does anyone know, if for some reason I don't like it can I swap back without a retune?
Old Oct 11, 2013 | 07:43 PM
Jesse's Avatar
Nope you would need to tune it back. The computer has to know the size of the throttle blades especially on earlier models IIRC. But you'll love it anyway
Old Oct 11, 2013 | 08:29 PM
BLKLS's Avatar
I figured that, I guess if you tune for x amount of air at x% of throttle it'll get just as concussed if you suddenly throw y amount of air at x% of throttle. Oh well.
Old Dec 28, 2013 | 03:30 PM
scotty_95's Avatar
im running 2.4 mani and tb and 2.25in catless exhaust and i didnt notice much low end loss but from 4k and up its like v tec over stock
brandon04
Oct 21, 2015 07:04 AM
patooyee
Oct 15, 2015 05:11 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
