quick question
tooooooo true
ya..if you mount it to an existing tranny and get the comp reflashed you will be fine
Last edited by NWAE Cobalt; Jun 6, 2008 at 10:12 PM. Reason: Automerged Doublepost
how is the computer different? wouldnt it just be an added computer for the tranny? i thought the tranny and engine worked off of different computers?
i dont get why though? wouldnt it be the same computer?
tons and tons of fabrication. you need to run a clutch, shift linkage, and the list goes on. its just not practical swap, but im not going to say it cant be done, it can if you have the time and money.
my mistake for not specifying
dude, you dn't need to get it reflashed
all you will probably have to do most likley is do a crankshaft variation learn
he's not getting a new pcm...just the motor for his car
Last edited by Sunburst_SS; Jun 6, 2008 at 10:24 PM. Reason: Automerged Doublepost
right...but is there not another computer that it needs to communicate with on the engine.....all the computers on the car are vinned to the car...and i KNOW that another cars pcm will not work..sooo....
HE'S NOT PUTTING ANOTHER CARS PCM IN
The PCM in his car is what will tell the engine what to do.....so the one he has in his car will work fine without reflashing. What he WILL have to do however is a crankshaft variation learn...so the PCM can learn the position of the crankshaft so it knows which injectors/plugs to fire.....
and yes another cars PCM will actually work if you do the VTD learn on it
