Quick Question
Old Mar 7, 2009 | 09:16 PM
wvarmyguard's Avatar
Quick Question
Im sure this has been asked before..Is there a How-To out there or anyone know what all I would need to install the 2.4 intake mani on my 06 2.2? I have searced the how to's and there is one for installing it on an 08 model. Just dont know if things would be different between the models.
Old Mar 7, 2009 | 10:08 PM
Whitty's Avatar
searchy mc searcherson... its gotta be a round here still i just really dont want to do it for you but you can find it in the how to section 100% guaranteed
Old Mar 7, 2009 | 10:35 PM
YzRider452's Avatar
Just help the guy. If you have an 06 your going to need the manifold, the o rings, the pcv gasket, brake booster hose and the gasket that goes in between the throttle body and the manifold itself.
Old Mar 7, 2009 | 11:06 PM
Red07SSNA's Avatar
Everything you need is in this kit from CED -- including installation instructions:
http://www.crateenginedepot.com/stor...t-W67C144.aspx
Old Mar 7, 2009 | 11:10 PM
adam12's Avatar
dose changeing the manifold help with hp
Old Mar 7, 2009 | 11:13 PM
DarkCobalt13's Avatar
shifts the powerband upwards. Meaning less power in low RPMs but a good gain at higher RPMs. IMO us 2.2s need all the low end power we can get......
Old Mar 7, 2009 | 11:16 PM
Red07SSNA's Avatar
People that have installed the 06-07 2.4 manifold and have dynoed to check the difference show an increase in HP/TQ from idle to about 3500RPM and from about 4500-6500RPM (as much as 19 HP above 6000RPM over the stock manifold). The HP/TQ drops a little between 3500-4500RPM without a tune due to the way GM has the fuel enrichment set up.
Old Mar 7, 2009 | 11:18 PM
That part I did not know. So with a tune, the low end loss can be fixed?
Old Mar 7, 2009 | 11:23 PM
Red07SSNA's Avatar
Yes. The 2.4s also have this lean fuel setup below 4000RPM. On a 2.2 you do not feel any loss when starting from a stop but you do feel it at part throttle at low speed. The real difference is in the top end where the engine obviously breathes better with the 2.4 manifold. You actually get more wheel spin with the 2.4L manifold off the line too...but to reset the learn values after installing the 2.4 manifold make sure to do an erase of the ECM through the OBDII port -- disconnecting the battery does not reset the learn values.
Old Mar 7, 2009 | 11:26 PM
hmmm, may be worth it after all.
Old Mar 7, 2009 | 11:28 PM
Red07SSNA's Avatar
I had it on my 06 LS and enjoyed using it...ended up trading my LS in on my 07 SS/NA. If I were to get another LS I would install the 2.4 manifold again.
Old Mar 7, 2009 | 11:46 PM
G5King's Avatar
Can you paint the manifold and it look decent?
What about the 2.4 TB also?
Old Mar 7, 2009 | 11:57 PM
I have already purchased the mani from a user on CSS I was just wondering what else I might need and a possible how to for installing it on an 06 model.
I do appreciate everyone's help!
Old Mar 8, 2009 | 10:40 AM
Red07SSNA's Avatar
I painted my 06 LS's 2.4 mani with Krylon silver engine paint and I have my 2.4's mani painted with Krylon red engine paint...only areas that I had a problem with was around the mount bolts -- paint chipped, but this would probably be the same if it was made out of aluminum.
https://www.cobaltss.net/gallery/fil...arged_2_4l.jpg
2.4 TB needs some tuning to make it work on the 2.2 -- it is NOT a bolt-on-and-drive mod!
Old Mar 8, 2009 | 11:59 AM
If you are doing the 2.2 tb then you need the adapter plate, adapter plate gasket, intake seals, PCV seal, and brake booster hose
If you get a 2.4 tb you wont need the adapter plate or gasket but you will need a Trifecta Tune
Anyone correct me if I am wrong
Old Mar 9, 2009 | 02:53 AM
Is there anywhere I can buy those parts separately?
Old Mar 9, 2009 | 10:11 AM
Red07SSNA's Avatar
You can get them separate at CED -- 1 800 441-5150
Tom at CED has the plates specially made.
brandon04
Oct 21, 2015 07:04 AM
dennis69
Oct 20, 2015 07:39 AM
patooyee
Oct 15, 2015 05:11 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
