Raiden8816's Supercharged Build
Old May 16, 2011 | 01:08 PM
SSfamilywagon's Avatar
Originally Posted by zerosk8ter83
I actually just got done with my sc build last sunday,Im having a few issues but thats only cuz i was tuned for the 2.5 bar but im riding a 1 bar.Alittle messy right now but it will be fix soon
I like the white under the hood. Why did you mount the TB upside down though?
Old May 16, 2011 | 04:49 PM
zerosk8ter83's Avatar
thankx!,limited space on the other side but i do plan to switch it soon
Old May 16, 2011 | 05:38 PM
Talic's Avatar
nice work, lets see more pictures
Old May 16, 2011 | 10:34 PM
Raiden8816's Avatar
Old May 17, 2011 | 01:47 AM
Looks good sir. Just need to clean up a lil more and get that tuning done. I wanna see what you do at the track
Old May 17, 2011 | 07:53 PM
so what kind of issues are you having?
Old May 17, 2011 | 10:06 PM
Raiden8816's Avatar
I'm only having idle issues at the moment.
The mk I base tune was very very very rich and blew black smoke from the exhaust lol, plus the idle was crap for being an automatic, so I had to brake boost to slow down/keep rpms at a stop.
I just got a revision from vince, which I dub mk II, and its less rich, no more black smoke from exhaust but the car still has idling issues.
For example, if I were to get into my car right now and start it from park like always, the AFR goes crazy and then car dies. I wonder if I were to clean the MAF that will solve the damn mystery.
Old May 17, 2011 | 11:42 PM
Raiden8816's Avatar
where does this hook up to?
Old May 17, 2011 | 11:48 PM
springerdesigner's Avatar
why are you using 80's..?
Old May 17, 2011 | 11:57 PM
Raiden8816's Avatar
I will be doing e85 later on....
But back on the subject at hand;
Now per this diagram, 744 is a hose that goes from the manifold to ? (I currently have that going to the boost gauge)
922, is the picture that I posted above (black canister)
912, is hooked up to the supercharge per the pix above again.
But what is confusing me is 911, which I believe is the mystery hose that should hook up to what?
Old May 18, 2011 | 12:38 AM
  #36
Nothing. Its not use on the 2.2 s/c set up.
Also I wouldn't go spraying anything and trying to clean the MAF. Could make it worse. MAF is a hot wire and sensitive to cleaners. Just give Vince time and let him try to tune it out. Patient is key to tuning
Old May 18, 2011 | 01:30 AM
  #37
Raiden8816's Avatar
I'm not touching the MAF since it was a PITA to move the intake lol
Old May 18, 2011 | 01:21 PM
  #38
Raiden8816's Avatar
Updated status, the mk ii tune was loaded yesterday and it has the shifting much smoother. Also the car no longer shoots black smoke. But I still am giving idling issues at a stop so I'm break boosting still til vince fixes the problem
Old May 19, 2011 | 09:42 AM
  #39
MP81's Avatar
What room issues are you speaking of when relating to mounting the throttle body the right way? I didn't have any problems...
Old May 19, 2011 | 12:43 PM
  #40
I think i got a bad throttle cuz im getting codes up the ass about them and my iat's for my intake arnt working.
Old May 19, 2011 | 05:33 PM
  #41
did you do your own wiring for the TB or did you use an adapter..?
Old May 19, 2011 | 06:59 PM
  #42
I had to rewire wires around.
Old May 20, 2011 | 12:44 AM
  #43
It sounds like you have wiring issue more then a bad TB. I'd recheck your wiring just in case. I used Beck's build thread for Raidens and his came out good
Old May 20, 2011 | 12:52 AM
  #44
Tcobalt421's Avatar
awesome dude, congrats im piecing together my own sc build right now
Old May 20, 2011 | 05:20 PM
  #45
this is what I was thinking. I actually used an adapter from ebay I found and had no issues.
Old May 21, 2011 | 03:40 AM
  #46
zerosk8ter83 I'd suggest re-going over your wires and soldering them if not already. As important as the Tb is to drivability, it will last longer over time.
Old May 21, 2011 | 03:45 PM
  #47
I already rewired and resoldered everything And it went away for awhile but i got a code from my iats's.fixed it code was gone for a day then came bak up. I havent got it scanned to see what it is.Im pretty sure it my map sensor cuz my car tugs when speeding up and it feels lean
Old May 21, 2011 | 08:20 PM
  #48
Raiden8816's Avatar
So update on the idling issue, drewbroo and myself flashed mk III and the car wasn't runnable at all. So we flashed back mk II. Seems like one concern was the MAF being so low on the intake, so we mocked up some piping which he had lying around for his LNF, didn't fix it. The second issue was the terminal velocity for the MAF, which was fixed after we slapped in his old K&N cone filter and removing the piping from earlier. The car is idling easier now with the AC on level 2 but it still dies at a stop/park.
I'm a bit worried in running TheRedFerret's LSJ throttle body so I may just deal with it until I have some cash to buy a brand spanking new LSJ throttle body and go from there.
Old May 21, 2011 | 08:31 PM
  #49
IonNinja's Avatar
as long as there are no bends around the MAF and as long as its pointing the right direction there shouldn't be any issues with the placement of it height-wise.
are you throwing any codes? what RPM does your car idle at?
Old May 21, 2011 | 09:26 PM
  #50
Raiden8816's Avatar
I'm now running around 1k now now thanks to drewbroo reflashing mk ii again and working the throttle after the flash. But if I were to drive like a normal automatic and come to a complete stop, the RPMs just drop and the AFR gets rich as hell.
I find myself now brake boosting around 1,200-1,500 to keep the car from dying when at a stop. Its not really a big deal its just annoying/different after driving a certain way for quite some time.
My new plan is to get a new LSJ throttle body to see if that works, I'm too worried to install Rey's tb, since it might be bad or kill my ecu like it did to his
