re-re question
Old Feb 24, 2011 | 11:10 PM
AzraelRaezier's Avatar
re-re question
okay so im going to sound like a complete idiot who doesnt know anything about cars but i was looking at a header/dp combination and i noticed 2 bungs, one in the header and one in the downpipe, i know i have a stock o2 sensor coming out the header but do i also have one in the downpipe?? or is the 2nd bung in the DP for a wideband?
Old Feb 24, 2011 | 11:15 PM
boost_junkie16's Avatar
You've got two 02 sensors. One in the header, one in the downpipe behind the catalytic converter.
07BoostedG5's Avatar
you could look under your car....
you have one on the down pipe (down stream) and one on the exhuast manifold
Old Feb 24, 2011 | 11:18 PM
BlackJackSS's Avatar
the one on bottom is hard to see from just looking under the car. you need to get under it to see it well.
Old Feb 24, 2011 | 11:25 PM
well dont strain yourself
Old Feb 25, 2011 | 12:24 PM
alright. so if u hook up a wide band you need to have 3 total bungs? where do you put the bung in for the wideband? im lookin at some aftermarket headers and downpipes right now to go with my catback.
Old Feb 25, 2011 | 01:30 PM
HyperMuffin's Avatar
Put it on the dp somewhere. Some companies you can order it to have an extra bung welded for your wideband of your could take it to any auto shop and they should be able to cut a hole and weld the bung on for you where you wanted.
Old Feb 25, 2011 | 01:51 PM
Make sure the wideband bung is IN FRONT of your catalytic converter or you're gonna get a fucked up AFR...
Old Feb 26, 2011 | 11:31 AM
the DP im lookin at is catless, so does it matter where it goes?
Old Feb 26, 2011 | 06:55 PM
flyy's Avatar
no you're fine that actually makes it easier lol but personally i wouldnt go catless man i made that mistake and will never happen again on a NA cobalt. makes the car sound like ****. High raspy sound. AND WAY TO LOUD. If you had a tc or sc car it would be different, so ive heard.
Old Feb 26, 2011 | 10:58 PM
alright ill stick to catted then. catted is about 60$ cheaper anyways. probably gonna just get a highflow cat then. thanks flyy, and one day i will be boosted
brandon04
Oct 21, 2015 07:04 AM
patooyee
Oct 15, 2015 05:11 PM
Iceberg
Sep 29, 2015 12:33 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
