rear disc breaks?
Old Jun 28, 2005 | 12:35 PM
dwarmenzerk's Avatar
rear disc breaks?
does the ls coupe have rotors? or are the drums like every other car that i like
thanks..
Old Jun 28, 2005 | 08:44 PM
moxjake's Avatar
drums, althoug i believe that discs are a (rather expensive) option.
Old Jun 28, 2005 | 10:53 PM
TarZan's Avatar
^yeah, rear disc brakes are an option.. with the ss
Old Jun 29, 2005 | 12:00 AM
MarcS's Avatar
The Stig
They come standard on the SS
Old Jun 29, 2005 | 02:51 PM
Maven's Avatar
4 wheel discs are standard and only available on the SS/sc Coupe.
any other car can be upgraded to them by purchasing the needed parts.(hubs, rotors, calipers, clapier mounts, and ABS module(you may be able to get by with just an ABS reprog but i think you need a whole new module) if you dont have ABS you will also need to plumb in a proportioning valve.
Old Jun 29, 2005 | 03:18 PM
stlurbanpunk's Avatar
the 2006 cobalt ss line up will all have 4wdb. (sssc, 2.4l coupe & sedan)
Old Jun 30, 2005 | 12:52 PM
Permafried-'s Avatar
I was iffy on the LS having rear drum brakes, but once I took a look at it with the 16" rims I realised it didn't look that bad at all. I've considered upgrading the rear brakes to disc brakes but in the long run the investment doesn't seem worth it to me, not to mention the number of modifications I might have to make to fit the front-disc brake kit on the rear (not putting a read kit on the rear or the discs are typically different sizes).
Permafried-
Old Jul 2, 2005 | 02:46 PM
saturnotaku's Avatar
Lack of rear discs are one of the few criticisms I have of the Cobalt. GM will tell you it was a cost-saving measure, but when I see cheapos like the Kia Spectra coming with them, I have to wonder. It's certainly not the worst thing in the world as even with rear drums, the car has very good stopping power with much better pedal feel and modulation than my ex-gf's Civic and current gf's Jetta. Imagine just how much better it could be if the base and LS models had rear discs, though.
Old Jul 2, 2005 | 03:00 PM
wikkymaster's Avatar
my cav had rear drums too so its not just the cobalts
Old Jul 2, 2005 | 05:09 PM
PenguinPIE's Avatar
exactly,.......it has enough stopping power and its not necessary to have rear discs..........we would save a will lot with drum brakes since we dont have to replace pads as often
Old Jul 3, 2005 | 03:21 PM
Maven's Avatar
Drum brakes are less expensive, last longer, and require less maintenance(typically)
And as a side note, when the NEON ACR(autocross ready) model came out Dodge put drums on it instead of the standard discs as found on the topline NEON.....btw...NEON's dominated Showroom Stock for many years.
Old Jul 3, 2005 | 11:28 PM
tiny's Avatar
the new ACRs come with 4 wheel disc
there is a hott white srt4 ACR being sold near me
Jan 12, 2016 12:01 AM
agentirons
Oct 16, 2015 02:11 AM
DANRICKARD
Oct 1, 2015 12:08 AM
Delta coupe
Sep 30, 2015 08:11 AM
Sep 27, 2015 08:53 PM
