Red's K04 Turbo Build
Old 04-26-2012, 09:01 PM
  #151
AzraelRaezier's Avatar
i like the progress your making. i found a used saab exhaust manifold for 50$ close by to me so i think ima pick that up. i looked at the tubro it uses and it was a garret turbo similar size to the k04 so i may swap. ive been reading up on compressor maps also and how to read them and think i may have found the turbo i wanna go with when i swap.
Old 04-26-2012, 09:33 PM
  #152
Axelthered05's Avatar
saab manifold for $50? nice
ended up geting the rest of the charge pipes striped and primed today minus the cold side charge pipe, ran out of paint stripper
Old 04-26-2012, 10:29 PM
  #153
klutch814's Avatar
good luck with the paint... mine chipps off so easy.. gonna get em powdered
Old 04-26-2012, 11:01 PM
  #154
did you sand them and do full paint prep or did you just paint over the polished aluminum??
Old 04-27-2012, 07:06 AM
  #155
klutch814's Avatar
scuffed, primed, sprayed, cleared, wetsanded, buffed, still nicks lol
Old 04-27-2012, 09:44 AM
  #156
meh I will keep that in mind when handling mine thanks for the warning I find it funny how when you paint somthing it always chips ar scufs but if you acidently over spray somthing its a bitch to get off
Old 04-27-2012, 11:45 AM
  #157
My sc is painted. I did like 6 coats of rustoleum 1000 degree clear on it. Engine enamel. Its holding up nice but i chipped it when i had to get a coolant line off becuz it was leaking. Other than that its holding up great
Old 04-27-2012, 04:23 PM
  #158
well we finaly figured out what the **** is wrong with me, went back to the doc today she took one look down my throte took a swab and low and behold I have strep so they geve me super strep killers to go with the meds im already on so that makes 6 hourse pills a day plus a decongestant, pain killers, and some other crap so around 16 pills a day the good news is that since the meds I was on before were already fighting the strep I dont have to go through another 24 hr quarantine so other than the increase in pills my life is not changing much
Old 04-28-2012, 12:32 AM
  #159
sweet. glad to see ur doing better.
Old 04-28-2012, 01:38 AM
  #160
thanks man hopefuly I can get this build done soon I NEED BOOST!!!
Old 04-28-2012, 11:33 AM
  #161
haha. i love boost but i wish i woulda went turbo instead of SC... now im looking for turbo parts.
Old 04-28-2012, 01:16 PM
  #162
Idk I like the set boost of the S/C but I like the possibilities of the turbo, I was thinking it would be cool to modify or fabracate a LSJ intake manifold to run the s/c but have the TB after the S/C that way it would be easier to tune to go twin charge and just have an aem truboost to turn on or off the turbo wastegate so when Im crusing around town the wastegate opens allowing only the S/C to operate then have the ability to swap to boost seting b on the tru boost and open the turbo and S/C for super boost but thats just an Idea I had but thats like 5k worth of parts along with needing to get stuff made and or buying the tools to make the parts and honistly I dont want to spend 800 on a welder that welds aluminum
Old 04-28-2012, 11:51 PM
  #163
thats way more complicated than anyone should want to tackle. plus the only good thing about a twincharge setup is you can say. im twincharged... a bigger turbo would produce WAY bigger numbers than a twincharge setup.
Old 04-29-2012, 12:04 AM
  #164
not exactly, true a biger turbo will generate more power but the more power it will produce the longer it will take to get to the high power the poing of the twin charge setup is to have a powerfull car thats still streatable without as much lag also like I said have the turbo only generating boost when the boost controler comands it that way the S/C makes all the power you need till some punk ricer pisses you off then its full boost time any way if I was going to twin charge I would endup puting a huge turbo on it which is why the S/C/turbo makes sence. but I dont forsee any projects like that in my future. from what I have read about peoples experiences its eather a hit or miss thing eather you get it right or you have catastrophic engine failure
Old 04-29-2012, 12:14 AM
  #165
yah.... haha im worried about blowing right now. i need to get a new clutch so i can dyno and see where im at exactly.
on a lighter note. i may have come across a LNF manifold and turbo for pretty cheap, under 600$
may go that route instead of trying to make that saab turbo manifold work on my car.
Old 04-29-2012, 12:49 AM
  #166
klutch814's Avatar
do it. i found my boost leak injector cup o-ring.. should be boostin this week but still need a tune..
Old 04-29-2012, 01:38 AM
  #167
tune before u boost or youll blow up.
Old 04-29-2012, 01:59 AM
  #168
klutch814's Avatar
its just to see if it holds.. not gonna stay in it.
Old 04-29-2012, 09:17 AM
  #169
good luck and watch those AFR's
Old 04-29-2012, 09:39 AM
  #170
klutch814's Avatar
have been like crazy man lol
Old 04-29-2012, 09:51 AM
  #171
i wouldnt do it without a bse tune cody. if you do your going to lean out faster than you can blink and blow.
Old 04-30-2012, 07:09 AM
  #172
first load of parts comes in today, still have not figured out what color to paint my charge pipes
Old 04-30-2012, 07:29 PM
  #173
a few of my orders came in today, got my vac leak tester, tbolt clamps, various couplers and a few other things, my zzp order is saposed to come tomorow then i will have everything i need except. the tune and the drill bits for drilling the block, the drill bits come in next week and the tune will be ordered thursday of next week then i will park the car on sunday the 13 and let it sit and drain the oil then the real work starts the 14th
Old 04-30-2012, 08:43 PM
  #174
klutch814's Avatar
sounds like a plan man. make sure you have everything! and why do you need drill bits for the block? also when removing the oil pan make sure to get all bolts or it WILL crack..ask me how i know....hahah
Old 04-30-2012, 09:07 PM
  #175
i need drill bits because in drilling the block for the oil return so that its in the same place as the lnf oil return, thanks for the heads up with the oil pan but this will be like my 5th time taking the oil pan off
Quick Reply: Red's K04 Turbo Build
