S/C kit?
Old Dec 10, 2008 | 04:24 PM
hotshoeracer's Avatar
S/C kit?
Does anyone sell a supercharging kit for the 2.2? I did a search but all the posts were really old and they were talking about how they were in development... Thanks
Old Dec 10, 2008 | 04:29 PM
Darkmanx's Avatar
nope. gotta buy all the parts from somebody whos going turbo.
Old Dec 10, 2008 | 04:35 PM
so you have to get parts off the old SC SS?
Old Dec 10, 2008 | 04:55 PM
umrdyldo's Avatar
Yes. It's not really hard look at Becks and Hunter Killer how to's
Just make sure to get all parts before you start.
Old Dec 10, 2008 | 05:27 PM
MadBrad's Avatar
http://socalecotecs.com/downloads/L6...ock_to_250.pdf
Look at the last two pages for all the parts you need.
Old Dec 10, 2008 | 05:46 PM
brandon2.2's Avatar
and I have a whole kit for sale $700 its the M62 off of a SS S/C, PM me if interested
Old Dec 10, 2008 | 06:13 PM
totalblackout's Avatar
i bought my kit for my 2.2 eco for my sunfire from www.crateenginedepot.com
Old Dec 10, 2008 | 10:11 PM
umrdyldo's Avatar
I really wish CED would set a cobalt kit that only has the parts and not the ECU tune.
Old Dec 10, 2008 | 11:29 PM
would that same kit not fit in the 2.2 balt? cause as to my understanding from when i was installing it on my car there was a couple wire end that i had to change, i assumed it was because the balt and fire/cavy map/maf were different
Old Dec 11, 2008 | 06:09 AM
HunterKiller89's Avatar
the kit will mostly fit. You will need a different throttle body, and a different tune at a minimum
Old Dec 11, 2008 | 06:19 AM
USMCFieldMP's Avatar
Rattlesnake Race Shop
I'll sell you my Ported S/C, Intercooler System, Injectors, Intake, GMPP Exhaust Manifold, and Downpipe.
Old Dec 11, 2008 | 07:53 AM
the throttle body is the stock one thats on the car it just get relocated onto the s/c. and when i went in to get the reflash at the stealership, they had some problems with the tech line cause for some reason they got a balt mixed up with a sunfire. so i take it that there is a flash for the balt. as well they mentioned that there was a authentication code that comes with the aftermarket s/c that is needed for the stealership to dl the flash.
Old Dec 11, 2008 | 08:05 AM
originaladrian's Avatar
interesting. i was not aware of a SC flash for the cobalt
Old Dec 11, 2008 | 08:20 AM
thats what they told me cause i had a huge hold up cause they were under the assumption that i had a cobalt and was adding the s/c to that. someone may want to call gm or the tech line to verify but as far as i know there is a flash for the 2.2 balt with the s/c
Old Dec 11, 2008 | 08:21 AM
if its tru this would save me allot of headache.
Old Dec 11, 2008 | 08:35 AM
id check into it man, call your local dealer and then ask them to call the tech line to see if there is a flash for the GMPP S/C kit for the cobalt. worth a try eh.
Old Dec 11, 2008 | 10:36 AM
06_ion2's Avatar
speedmafia sells procharger kits
Old Dec 11, 2008 | 12:35 PM
Viper33884's Avatar
Thanks for ever getting back to me in your sale thread.
Old Dec 11, 2008 | 04:16 PM
ok so basicly GM does make a kit for the 2.2 but some modifications would have to be made for it to work in a balt right?
Old Dec 11, 2008 | 04:49 PM
yes they do make one for the 2.2. technically it would bolt up. but dont quote me on fitting it into the car/tuning or any of the electrical hookups
Old Dec 11, 2008 | 05:03 PM
there is NO tune for the cobalt. they have one for the cavaliers and the sunfires, but that is it. any dealer that says otherwise is misinformed (and we all know how wrong dealers often are). I'm not sure how they run the vaccuum lines then on the cavalier kit since i used parts off of a SC cobalt..and if you do it this way, you'll need the larger TB
Old Dec 11, 2008 | 05:28 PM
yeah one thing that did come with my kit was the tb adapter so i could keep my stock tb
Old Dec 11, 2008 | 08:14 PM
thta makes sense. so i guess you need either a LSJ TB OR a TB adaptor from the cavalier kit
Old Dec 11, 2008 | 08:26 PM
correct. are the throttle bodies the same as the balt and fire? doesent the balt use a maf sensor?
Old Dec 11, 2008 | 09:57 PM
umrdyldo's Avatar
We have MAF sensor and Electronic Throttle Body. Now the adapter you are talking about, is that to mate the 2.2TB to the supercharger? Cause if so that seems like a big pain in the ass. I would thing we would be better to just put on a 2.4 TB with an adapter plate.
