SCDyne Header
Old Jul 2, 2006 | 01:13 AM
NewCobalt06's Avatar
SCDyne Header
I am seriously considering this header. I have an 2.2L motor. I have a 2-1/4 catback already. It seems a lot better than pacesetter as far as quality. Would this header hurt my gas milage? I don`t like 1-2 MPG decrease but anymore than that I won`t be happy. Has anyone tryed this header. And if so did you use the header wrap. I have the Weapon R intake. So I might use header wrap. This header had 1-3/4 primaries with a true merge 2-1/2 collector. I think it is designed more for the 2.0L SC. But what do you guys think.
Old Jul 2, 2006 | 01:15 AM
Joewit's Avatar
I dont know if it will fit and also there is some threads on here abouth people having problems with getting their header after paying for them.
Old Jul 2, 2006 | 02:01 PM
bykryder83's Avatar
it will work it will fit the 2.2 2.4 and 2.0
Old Jul 2, 2006 | 02:18 PM
patathSS's Avatar
Originally Posted by 97cavie24ls
header wrap is deadly for headers on a street car
as well voids warranty almost they companies that i know of
What do you mean? I'd like to see some facts or something that makes this a valid point. Just kind of an interesting comment.
Old Jul 2, 2006 | 03:20 PM
IonNinja's Avatar
because it traps in heat and slowly breaks down the header material over time
not worth it.
Old Jul 2, 2006 | 03:23 PM
victory_red_SS's Avatar
LSX RWD S/C conversion
Be very cautious of SCDyne. I personally know one SS\SC owner who paid for his awhile ago and he is still getting the run around. He has not received it "YET".
Old Jul 2, 2006 | 03:25 PM
IonNinja's Avatar
i know of an entire redline community who received absolutely shitty headers, not even usable.
BUT I think hes gotten those problems fixed, atleast I hope.
Old Jul 3, 2006 | 12:47 PM
slowion2's Avatar
doubt it, besides which if it's the same design it's still ****
hold off for a better design or look into getting one built for yourself, it'll save you the headaches this brand will bring
Old Jul 3, 2006 | 12:50 PM
patathSS's Avatar
not worth it.
What's a better alternative for preventing heat from entering the engine bay?
Old Jul 3, 2006 | 12:58 PM
Matty's Avatar
Yep still waiting. I am hoping for this week
Old Jul 3, 2006 | 01:04 PM
slowion2's Avatar
an actual thermal coating
what ninja is referring to is that you will be keeping heat in the metals without escape much longer than originally intended. that will increase the stresses on the materials and can cause premature failure. I've seen some that self destructed from wrap, and some that were fine, so use at your own risk, but I dont' think I'd roll the dice.
thermal coating isn't nearly as drastic. you can also find a way to keep the factory heat shield down there to deflect heat away from the engine bay toward the ground and back, just an idea.
Old Jul 3, 2006 | 01:21 PM
patathSS's Avatar
The impression i was under is that header wrap allows the exhaust gas to stay hotter and expel faster. I can see how this would be hard on the header but what about a low degree header wrap? Like a 1000 degree wrap. Or is it just that the heat stays within the header so much longer that causes problems?
Old Jul 3, 2006 | 04:47 PM
slowion2's Avatar
bingo
sure you want heat retention for scavaging and such, but too much heat on the materials is no good over time. now if it will help direct the heat out but still dissipate then it's good, but if it just holds it in, you get what I mentioned earlier
Old Jul 3, 2006 | 05:05 PM
bykryder83's Avatar
the scdyne headers looked fixed to me my buddy riceeater just put the new one on his car and it loked good to me,2.2 2.4 and 2.0 are basically all the same motor different internals on each the 2.2 and the 2.0 are exactly the same but the 2.0 has beefed up internals and its destroked from 2.2 to 2.0 so any header for the 2.0 WILL work for the 2.2
Old Jul 3, 2006 | 05:29 PM
slowion2's Avatar
sure will, I"m running a 2.0 manifold right now since I got it next to free and needed a quick fix for something.
rice eater (bryan) has one of the "fixed" ones? I'll have to look on the "other" forum and see if he put pics up. if he's actually running one I'm going to assume it's at least a decent improvement over the original release.
Old Jul 3, 2006 | 08:46 PM
bykryder83's Avatar
yeah the other one i think was a tog and i sucked bad,in gettin the old header and rewelding it other than that its all good.....scdyne tog same company,yeah his car is up and running and its badddddddd
Old Jul 4, 2006 | 02:30 AM
97cavie24ls's Avatar
i work at pacesetter , and here is pics of 2 header that came back for warranty , that i declined because they were wraped
if you look closely at them you can see dots , and where the lines from the wrap , ive seen headers come back where the metal moved like rubber
ive got 1 more header from a ohv cavalier that is worse than these 2 , that i need pics of
for give them being huge
Old Jul 4, 2006 | 02:35 AM
patathSS's Avatar
Wow those look in pretty rough shape too. How old were they? What material were they made of? Were they ceramic coated? Thanks for the info.
Old Jul 4, 2006 | 12:54 PM
1SloBowtie's Avatar
So is the moral of this thread the SCDyne header is ****? That's what I've gathered...
Old Jul 4, 2006 | 02:12 PM
IonNinja's Avatar
damn those headers are rough looking, hope mine doesn't crack anywhere!
p.s. - hook me up with a job at Pacesetter
Old Jul 5, 2006 | 01:51 AM
16 gauge mild steel , not ceramic coated
and id say 4months to no more than 1 year , and not in road salt climates
Old Jul 5, 2006 | 01:57 AM
patathSS's Avatar
Ok, thanks. I am really worried now. haha I need to eliminate some of the temps in the engine bay so my ice box and supercharger don't heat up so much. I bought a roll of cheap header wrap but now I don't know if I want to use it on my TOG header. I may and then just buy a new header later. Anyways, thanks for the help.
Old Jul 6, 2006 | 03:19 AM
i would use the header wrap on the parts you want to keep from getting into , the lines , ice box
ceramic coating really helps alot with temps , as does a header that has less bends in it
while at sema last year , we were next to a guy that made and sold header wrap , he wasnt aware that alot of header companies void their warranty when wrap was used , he said he would add that it might and to checkwith the manufacture of the header
and he did agree that wraping parts you want to keep heat out of would work as well
goaliemo
Sep 28, 2015 01:37 PM
z28addiction
Sep 28, 2015 12:03 AM
budah93
Sep 15, 2015 07:23 AM
hacadacalopolis
Sep 8, 2015 11:42 PM
