Secondary Air Injection on late production 2006 L61's
Old 04-11-2008, 11:04 AM
  #301
avenger09123's Avatar
yeah true, or I can find out the voltage for sure by sticking an Holmes meter between the sensor and the wire back to the PCM. You wanna roll by today or sunday we can give it a go?
Old 04-11-2008, 11:15 AM
  #302
kkanowitz's Avatar
PM sent.
Old 04-16-2008, 10:10 PM
  #303
showbalt88's Avatar
i own 06 ls sedan with sai and one cat
Old 04-16-2008, 10:56 PM
  #304
Ok...
Old 04-19-2008, 11:17 AM
  #305
CobaltLs_14's Avatar
What size plug or flange would fit where the 02 sensor goes at the base of the header? i found a way to make it work for CA users.
Old 04-19-2008, 02:23 PM
  #306
I'm old school
Halfcent's Avatar
I don't know, but the O2 sensor really has nothing to do with this system.
Old 04-19-2008, 03:24 PM
  #307
Blue_Balt's Avatar
Halfcent's right. No LSJ 2.0L or LNF 2.4L has , will, or ever will have the SAI system. SAI only comes on L61 2.2L motors, and even then, not on all of them, it seems they were made and spread out throughout delivery.
2.4 engine is the LE5 not the LNF.
Old 04-19-2008, 03:49 PM
  #308
Then what could i do to plug that hole up? what i'm really looking for is a flange to fit in there.
Old 04-19-2008, 05:04 PM
  #309
I'm old school
Halfcent's Avatar
I think you are talking about the air injection hole, not the O2 bung, right? In that case, I still don't know exactly. But I do know that hole isn't threaded like an O2 bung. It just a plate with two bolts that hold it. So you could fab up a simple steel plate and drill the holes to match.
Old 04-19-2008, 09:18 PM
  #310
Yeah the air injection is on top of the stock header and the o2 sensor at the base of the header is plugged, but the GMPP header isnt plugged and a found a way to to still have the air injection and route it to the o2 sensor and still pass smog in ca...
Old 04-20-2008, 02:02 AM
  #311
I'm old school
Halfcent's Avatar
Oh, well, you didn't mention that where trying to use a GMPP header. That's kind of important. I'm afraid I don't know. But I can tell you it still sounds like far too much work just for CARB requirements. Remember, this system only runs for like the first minute your car is on. If you are using an aftermarket header and trying to retain the system just to keep the CEL off, I would just leave the air injection line disconnected and venting to atmosphere rather then trying to plumb it into the O2 bung.
Old 04-20-2008, 02:26 PM
  #312
Oh So it only runs as soon as the engine starts up the cuts off? i dont know if i'm getting this right... but its not to much work its actually really easy if u know what your doing...
Old 04-20-2008, 06:51 PM
  #313
Yes your right, the one thing you need to consider is if the o2 sensor in the exhaust picks it up or not, thats the deciding factor to determine whether you can do that.
Old 04-25-2008, 07:50 AM
  #314
chrism0589's Avatar
i'm not sure if i have SAI or not. but i think i do. the thing is that i installed a k&N CAI and ever since i did that my car idles when i turn it on. would SAI have anything to do with that?
Old 04-25-2008, 03:46 PM
  #315
Sarbae's Avatar
your car idles when you turn it on? so does mine...
what do you mean?
Old 04-28-2008, 04:00 PM
  #316
chrism0589's Avatar
what do you mean?
well when i turn it on. like in the mornings. the revs go down to like 300 then up to like 900 does that a few times then u hear like an air sound then it stops.
Old 04-28-2008, 05:43 PM
  #317
I'm old school
Halfcent's Avatar
Using the pictures in this thread you should easily be able to know if you have SAI. However, the problem you are describing has nothing to do with it.
Poor idling and oscilating RPMs with the K&N intake might be because you still have the SAI intake hole open on the intake pipe. The K&N pipe is the only one that actually has that.
Old 04-29-2008, 07:51 AM
  #318
chrism0589's Avatar
well i just went down to my car and checked. i guess i do have SAI. and i also checked the intake pipe and it looks to me like everything is connected. is there anything else it could be??
Old 04-29-2008, 11:05 AM
  #319
I'm old school
Halfcent's Avatar
Nothing else that would have to do with SAI. Take it to the shop. And when you do, leave your intake alone.
Old 04-29-2008, 03:05 PM
  #320
chrism0589's Avatar
what do u mean leave my intake alone??
Old 04-30-2008, 05:18 PM
  #321
No no hold on a sec.....
Your new intake is flowing much more air through your MAF than your old intake....if you havent unplugged your battery and allowed your car to relearn its fuel trim settings it will do that.
It pulls a ton of air in at startup because the intake is much better and then drops the RPMS because its getting too much and then kicks it up and then drops it down while its finding the right fuel trim to get it to the 800rpm idle with so much more air coming in.
Unplug the + on your battery for abotu 30 mins and let it reset and then start up your car and let it relearn all the fuel trims for your new intake....
it might take a week or so to get it to stop doing that...but it will eventually either way....
Old 04-30-2008, 07:55 PM
  #322
chrism0589's Avatar
alright then i'm going to do that right now thanks.
Old 05-22-2008, 12:05 PM
  #323
97cavie24ls's Avatar
as a update since i still get asked questions
currently there is NO plan to move forward on the pacesetter header to work with the SAI system
Old 05-22-2008, 03:59 PM
  #324
I'm old school
Halfcent's Avatar
I don't expect there ever will be either.
Old 05-27-2008, 02:15 AM
  #325
franchise78's Avatar
Ok, I got my cobalt on saturday and today I come on this board to join and learn a bit and I find out I have this system. I read the post that mrgoodwrench78 had on here thanks to halfcent. Now if i have my technician do this to eliminate the sai I can take all the parts of for it and replace with any that I choose? I do appreciate everyones time and effort on this and sorry If I missed the answer on the other 17 pages I read on this..
Quick Reply: Secondary Air Injection on late production 2006 L61's
