Simple Question
Old Aug 22, 2008 | 10:07 PM
pykie's Avatar
Simple Question
When you do the 2.4 intake mod and you run the 2.4 throttle body
you need:
a tune!
and what about the plug to pug it all in does the factory one with the 2.2 throttle body fit?
Old Aug 22, 2008 | 10:48 PM
YzRider452's Avatar
The 07 is a different harness. I have the throttle body but it doesnt clip in. There has to be a way to wire it, but i aint the guy to try that.
Old Aug 22, 2008 | 11:08 PM
pykie's Avatar
Okay thanks, I guess i will stick to mine for now.
thanks again
Old Aug 26, 2008 | 09:46 PM
montecarloman's Avatar
There has been posts on this subject. You cant run a 2.4 TB with a 2.2. The Computer detects the extra air flow as a vacuum leak and puts the car in limp mode.
Old Aug 26, 2008 | 10:59 PM
YzRider452's Avatar
Yes you can run a 2.4 tb on a 2.2, people are doing it. The only problem is that the 07 cobalt uses a different harness on the throttle body than the 05-06 that use the same harness as the 2.4.
Old Aug 26, 2008 | 11:07 PM
sidewidnerbiker's Avatar
what about a ls1 tb? Will it fit/work?
Old Aug 26, 2008 | 11:29 PM
That can be rewired. How are they overcoming the programing issue? Did Trifecta add that to their list or did HPtuners get smart?
Old Aug 27, 2008 | 12:14 AM
silver_ecotec's Avatar
you need:
a tune!
to run the 2.4 mani, you need the adapter from CED, unless you have a 07 plus in which the bolts r the same, if you put a 2.4 TB on any 2.2 u will hit limp mode, there is no need for a 2.4 mani unless your boosted, even with he mani u dont need it...they tested it already, even when it was all tuned for, the 2.4 flowed the same as the 2.2 one...
Old Aug 27, 2008 | 01:29 PM
stripes ss's Avatar
hey, guys i have a 2008 cobalt 2.2 and want to drop a turbo in but i dont know what i will need i am a nub, i know gay but i really need some help?
Old Aug 27, 2008 | 08:39 PM
Jrose's Avatar
I'm in the same boat as the guy above... 2008 2.2l w/ manual and looking to go turbo. Not really sure where to start though.
Old Aug 27, 2008 | 08:44 PM
XM15's Avatar
Research.
Best place to start.
This way when you need information you can ask very specific questions. Its hard to give advise when there are too many generalities. ie What does the stock 2.2 TB flow? as opposed to: How much hp can my ride make?
brandon04
Oct 21, 2015 07:04 AM
Iceberg
Sep 29, 2015 12:33 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
