Spark Plugs
Old Sep 10, 2008 | 08:36 PM
Borderlin3's Avatar
Spark Plugs
I searched, tried a couple different words and couldnt find a direct answer. what is your opinion on spark plugs? What do you think is the best?
Old Sep 10, 2008 | 08:37 PM
XM15's Avatar
Just get OEM. Unless you're running nitrous or some kind of forced induction.
Old Sep 10, 2008 | 08:38 PM
JimzSS's Avatar
What is the application?
Old Sep 10, 2008 | 08:41 PM
Borderlin3's Avatar
stock.
oem, alright. I didnt know if there was any REAL gains in performance or better fuel economy by going aftermarket.
Old Sep 10, 2008 | 08:51 PM
XM15's Avatar
No, there shouldn't be any measurable difference between the brands, especially at our power levels. What is important is that they are gapped properly.
Old Sep 10, 2008 | 09:17 PM
JimzSS's Avatar
Ac baby!
Old Sep 10, 2008 | 09:19 PM
Spanky's Monkey's Avatar
stock or oem with or without nitrous. i don't know why everyone says to go cold on the plugs when on the bottle with the 2.2 it's a waste of money and time.
Old Sep 10, 2008 | 09:24 PM
XM15's Avatar
So until what power level are the stock plugs good to?
Old Sep 10, 2008 | 09:28 PM
their fine for a 75 shot on the 2.2 and that's on 87 octane. on 93 octane with the tune it's still golden but much more so.
Old Sep 10, 2008 | 09:40 PM
XM15's Avatar
And the injectors are fine up to that point as well? It seems that those would have a pretty high IDC at that point.
Old Sep 10, 2008 | 09:41 PM
Jn2's Avatar
Jn2
i know ir un stocker on my set u, but i dont have anything special, full bolt ons...and with a 75 shot i recommend 1 step colder plugs, but for n/a with no type of f/i(s/c, turbo, cheater spray) stick to the delco iridiums, 41-103 is the part #
Old Sep 10, 2008 | 09:45 PM
i put 25 bottles through this bitch on stock plugs and it never ever skipped a beat. as to the injectors it don't matter cause your fuel supply is being pulled from the rail itself which does not effect the injectors duty cycle. and to answer the unasked question the feul pump holds up just fine.
Old Sep 10, 2008 | 10:19 PM
ScottxKillyou's Avatar
It's getting close to tune up time for me so I ordered the NGK laser series plugs to try them out. I'll let you know how it goes when I change them
Old Sep 11, 2008 | 06:57 PM
StrongIslandBalter's Avatar
so why do people buy ngk lugs and bosch plugs do they offer any gain in performance
Old Sep 11, 2008 | 07:48 PM
i tried ngk cold and wasn't happy with the dd performance so i swapped back to stock and never looked back.
Old Sep 11, 2008 | 11:40 PM
Red07SSNA's Avatar
Because they believe the ads, or their buddys brag on em and talk them into wasting money. GM spent time and money on research and developement to find the right sparkplugs for these engines -- do you think the aftermarket will actually spend big bucks to try to come up with a better sparkplug? They'd never make a profit or their plugs would have to be really expensive after proving the difference.
I've run street and mildly modded cars on the dragstrip and found the factory plugs run just as good as the aftermarket plugs. Never was any faster with the "performance" aftermarket plugs -- and they always cost more! Wasted time indexing the plugs too and that didn't provide any better times down the track either.
Old Sep 12, 2008 | 02:28 AM
Bosch plugs are **** and the I've heard a lot of good feedback about NGK. They cost the same as OEM so I'm gonna try them out.
Old Sep 12, 2008 | 09:20 AM
yellow_cobalt's Avatar
NEVER BUY BOSCH PLUGS!!!!!!! they are absolute junk. they foul out very quickly.
personally, i love the ac delco rapidfires. i did a two year test with some spark plugs in my 97 saturn sl2, and found the rapidfires brought the best, most consistent gas mileage, held up the best, and had consistent performance.
performance wise, i believe the best is probably going to be a basic cooper plug due to lowest resistance. is this going to add power? no, but at the performance stand point, it out performs. but it does have a lower melting point the other electrodes.
Old Sep 22, 2008 | 06:37 PM
Finally installed the NGK Laser Iridium's. So far so good
Old Sep 22, 2008 | 10:03 PM
massivematt's Avatar
Bosch Platinum Iridium +4 plugs are perfect. I have had them for a while now and they make it run excellent.
DarrenGC
Dec 24, 2021 01:55 PM
agentirons
Oct 16, 2015 02:11 AM
717ssbalt
Oct 2, 2015 04:01 PM
CobaltSS 16
Sep 29, 2015 01:53 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
