Spring Install
Old Jan 14, 2009 | 10:35 PM
boltedbalt's Avatar
Spring Install
hmm where did all of you guys get your springs put in at i got a quote from midas and it was like 300 to get all 4 springs installed to me that seemed reather high any ideas?
Last edited by boltedbalt; Jan 14, 2009 at 10:35 PM. Reason: Automerged Doublepost
Old Jan 14, 2009 | 10:42 PM
jlmd's Avatar
$300 is a tiny bit high. Expect to pay at least $50 per spring at a mechanic...and thats probably the cheapest you will find. $250 is the price I was quoted when I did mine a couple years back.
Your best option is to buy the few tools needed and take a day and do them yourself...it will likely take you a while the first time, but they are very easy once you know what you're doing...I recently swapped all my struts and shocks with fe5's and did the whole job in under an hour..
Old Jan 14, 2009 | 10:44 PM
Switt23's Avatar
most auto parts store rent out Spring compressors. Then look up the how to and go nuts.
To be honest, it's probably one of the easier mods to do with a buddy's help.
Old Jan 14, 2009 | 10:45 PM
boltedbalt's Avatar
hmmm what shop was that quoted at? i was thinking of going to goodrich or firestone...where can i find 50 bucks a srping
Old Jan 14, 2009 | 10:47 PM
jlong3382's Avatar
I put them in myself. My friend dad has his own autoshop. It took me about 4 hours. I paid $245 shipped for my Sportlines at Turbo Tech Racing + $70 for a 4 wheel alignment with a camber kit at my dealer. I LOVE my springs
PS: The same dealer gave me a $350 estimate for the install and alignment. So I did it myself. Its not very hard........I promise.
What springs are you getting?
Old Jan 14, 2009 | 10:49 PM
Halfcent's Avatar
I'm old school
Here is the front:
https://www.cobaltss.net/forums/how-guide-43/front-strut-spring-r-r-23418/
The rear is silly easy.
Old Jan 14, 2009 | 10:50 PM
jlong3382's Avatar
Originally Posted by Halfcent
Here is the front:
https://www.cobaltss.net/forums/showthread.php?t=23418
The Rear took me 25 mins. LOL
Old Jan 14, 2009 | 10:52 PM
Switt23's Avatar
took me about 10 . Crack the back support loose. Have buddy pull like crazy on bottom of spring seat and shove new spring in, retighten bolt.
Old Jan 14, 2009 | 10:54 PM
jlong3382's Avatar
You didnt drop the axel? Cool
Old Jan 14, 2009 | 11:19 PM
pykie's Avatar
Do them your self!
it took me like and hour to do mine.
and i marked everything so when i put it all back together my car wasnt out of alignment much. my tires lasted 30,000 km out of aligned.
but i wouldnt pay somone to do something to simple.
Old Jan 14, 2009 | 11:25 PM
stenguyen1's Avatar
too bad your not in houston bc my gm of houston club i installed mostly everyones springs my self, all you need is the spring compresser from like advance and 13 mm, 19mm, 21mm, hammer, and jack and jack stands. it just takes like 30 - 45 minutes with me and my brother. the back is easy like pie and the front is easy too just takes time to be careful with all things. i only charge food to pay for the install lol
Old Jan 15, 2009 | 07:11 AM
VRCobalt's Avatar
Rear are easy as hell 10-20 min. Now for the front, if you dont want to do them, I recommend taking out the strut assembly and then take it to a shop, thats what i did and only got charged $50 for swapping the springs. After taking out the frt wheels, its only six bolts to remove the strut assembly.
Old Jan 15, 2009 | 07:30 AM
HunterKiller89's Avatar
at my local tuner shop i got quoted $200 for springs and struts...so $300 is def. too much for just springs...especially since the Koni's aren't a simple bolt on install...there's cutting
Old Jan 15, 2009 | 09:50 AM
EvilMonkey's Avatar
I've changed mine like 4 times, get a lil faster each time. should only take 45 minutes - 1 hour your first time... Might as well buy the compressors ($40 autozone)
Back is stupid easy, just take your time, have fun...
Old Jan 15, 2009 | 09:52 AM
D4u2s0t's Avatar
like said, do it yourself or have a local member help. it's really not hard.
Old Jan 15, 2009 | 10:16 AM
NOvelociti's Avatar
Doesn't maven have a method of changing springs that you dont need to compress the springs? Ill look for it right now.
edit: Found it
https://www.cobaltss.net/forums/show...4&postcount=42
Last edited by NOvelociti; Jan 15, 2009 at 10:16 AM. Reason: Automerged Doublepost
Old Jan 15, 2009 | 04:13 PM
VRCobalt's Avatar
edit: Found it
I never would thought of that, I coulda saved $50. Oh well, I'll remember that for next time. This makes it easy enough for someone that has never worked on a car.
Old Jan 15, 2009 | 07:42 PM
EvilMonkey's Avatar
hehe, I've seen people use a pair of vise grips on the the shaft to absorb the release of the spring. Highly not recommended...lol
Old Jan 16, 2009 | 12:40 PM
Maven's Avatar
You realize changing springs and changing struts is the same operation right???? hehe
Old Jan 16, 2009 | 11:07 PM
swapping struts, yes, but the Koni's reuse the stock strut housing,and involves a little cutting to make it work. Basically, it's not a bolt on solution. But yes, for any other strut (or the rears for that matter), its the same deal.
Old Jan 17, 2009 | 11:25 AM
Maven's Avatar
I know that, you got a quote of $200 for Konis installed?
Old Jan 17, 2009 | 12:45 PM
Halfcent's Avatar
I'm old school
If you did, that's pretty good.
Old Jan 17, 2009 | 02:27 PM
NWAE Cobalt's Avatar
ive done 5 cobalts...all in my driveway with my tools lol
Old Jan 17, 2009 | 02:34 PM
Maven's Avatar
Old Jan 17, 2009 | 05:23 PM
lawl, just saying that you dont need to take it in
