squires turbo systems remote mount, update
Old Apr 28, 2008 | 04:51 PM
xCobalt05x's Avatar
UPDATE on the squires turbo systems remote mount instalation
DTP has delayed the finished product till friday this week...
I went up there today and saved myself 190 in labor by installing the injectors myself...
The Trifecta tuning is tuned for 10lbs of boost and 60# injectors so no i didnt put it on the dyno since the turbo install isnt complete... But, i did how ever load up the tune, installed the 60# injectors and reved it up a few times to make sure everything checked out and so far no problems... no cel's
So i can now say im the first 2.2L cobalt tuned and running with 60# injectors....
the transmission tune work's wonderfull, park/neutral rev limiter was adjusted from 4k stock to now 5k... didnt get to test out the rev limiter for while in gear but im sure it works just fine, i'll find that out later this week... maybe, lol
One other thing, Vince told me he moved all my shift points to 7,000 and the rev limiter to 7500rpms
Last edited by xCobalt05x; May 6, 2008 at 08:36 AM. Reason: updated info on my new post
Old Apr 28, 2008 | 04:52 PM
umrdyldo's Avatar
Very nice job. Can't wait for a final tune and numbers.
Good luck.
Old Apr 28, 2008 | 04:53 PM
XM15's Avatar
Very cool. Subscribed.
Old Apr 28, 2008 | 04:55 PM
mkulrey13's Avatar
how is the tuning via email.....
Old Apr 28, 2008 | 04:56 PM
gtxsport11's Avatar
very nice i myself will be getting that tune for my garrett turbo kit in the future
Old Apr 28, 2008 | 04:59 PM
xCobalt05x's Avatar
haven't had to do an update tune yet since the turbo is not done so we didnt do a dyno pull... he used a fuel map and timing map from a turbo 2.4 SS and just copy and paste the numbers to the 2.2L tune.
We should only have to fine tune the fuel map and timing since im running the same boost level as the 2.4L ss turbo he got the tune from...
We will be making one dyno pull, data log, adjust tune if needed, dyno pull one more time to make sure its driveable... and then.... street tuning to fine tune it for max power output
Old Apr 28, 2008 | 06:11 PM
Sw4y1313's Avatar
Are you running the same turbo as the 2.4? if your not then its going to be off by a bit. I hope it works out but its probably not going to be quick because of logging, making a change and hoping its enough, then doing it all over again. Good luck dude.
Old Apr 28, 2008 | 06:18 PM
xCobalt05x's Avatar
hence why i said "we will have to fine tune it" lol
reading post FTL
on a serious note, i already touched on that bro
Old Apr 28, 2008 | 06:37 PM
Sloco Productions's Avatar
i dont understand y the guy doesnt give u the program so u can change settings while tuning...so ur gonna run on the dyno...mark down what needs to be changed and email him and he changes it?
i mean ull be sending the tuner back when its done anyway
Old Apr 28, 2008 | 06:39 PM
Sw4y1313's Avatar
dont worry i read your post. but what i was saying is since your turbo is completely different then the 2.4's turbo then its going to be even worse, especially since your engines are different. Your compression is dropped as well. Im thinking you will pull around 250whp on 10psi on your turbo with your current engine mods.
Old Apr 28, 2008 | 06:46 PM
xCobalt05x's Avatar
because if he does that then he wont make any money, this is how it works... we dyno with him on the phone, give him the numbers feed back and he re-writes a tune on the spot, emails it, load it up via SD card into the HP iPaq PDA... flash the new tune, dyno pull again, turn around time probably 35 min tops....
not getting into numbers in the thread. PM me if you want some numbers of this turbo on some honda engines running 9psi with the remote mount set up
Last edited by xCobalt05x; Apr 28, 2008 at 06:46 PM. Reason: Automerged Doublepost
Old Apr 28, 2008 | 06:52 PM
but havent u already payed for the tune b4 he sends u the tuner?....so y not send the tuner and program...then u send back the tuner and the program would be useless to you right?
Old Apr 28, 2008 | 06:54 PM
xCobalt05x's Avatar
nope, because its loaded up onto a PDA so you could load it onto your own personal PDA and rob him from money.... what he is doing is very very business smart, but he is hooking me up by dyno tuning with me at no extra cost... he has a lot of 2.2's in WA area that are waiting to see what resaults i get before they buy their turbo kits.... looks like i might be brining him some business in the future if all goes well
and i already tried hooking it up to my personal laptop, he has all functions disabled on the PDA other then being able to load up your Tune to your car
Old Apr 28, 2008 | 07:01 PM
oooo now it makes sense....thanks for clearing that up....i plan on using his services in the next year sumtime when i turbo mine...hopefully he will have a good 2.2 turbo tune he can use...like urs lol
did u mean to say WA or VA?
Old Apr 28, 2008 | 07:03 PM
victory_red_SS's Avatar
LSX RWD S/C conversion
Looking forward to seeing your results on "tuning" day.
Old Apr 28, 2008 | 07:08 PM
xCobalt05x's Avatar
i'll snap some screen shots of what it looks like.... stand by for pics
WA as in washington the state
Last edited by xCobalt05x; Apr 28, 2008 at 07:08 PM. Reason: Automerged Doublepost
Old Apr 28, 2008 | 07:22 PM
ok cause ur info says Norfolk VA thats y iwas like huh?
Old Apr 28, 2008 | 07:34 PM
xCobalt05x's Avatar
me too rod, lol
yeah, the car is being tuned on the otherside of the country and so far soo good, lol
at this point it checks for the engine that is loaded on to the PDA... the spark plug then "glows" if its connected and then loads up the tune automaticaly... upon completion it then auto loads the transmission tune (if you have an automatic and asked for a TCM tune)
Last edited by xCobalt05x; Apr 28, 2008 at 07:34 PM. Reason: Automerged Doublepost
Old Apr 28, 2008 | 07:41 PM
wow its all high tech and shiza...whys your car on the other side of the country?...and u have the tuner?...no comprende lol
Old Apr 29, 2008 | 12:46 AM
xCobalt05x's Avatar
lol the car isnt, lol the tuner came from the other side of the country
Last edited by xCobalt05x; Apr 29, 2008 at 12:46 AM. Reason: Automerged Doublepost
Old Apr 29, 2008 | 01:18 AM
Jn2's Avatar
Jn2
alright i am counting on youto make this work, i have already started my turbo build on the assumption trifeca can tune for it, i will be running a big 16g turbo w/a fmic, set to stock boost, as it is a internally wasegated turbo, will be using stock injectors, cuz i know dam well they arent max'd out right now, will tune after i get it all done, and will see if it needs any fine tuning, which im sure it will ned some adjustments, but i wont be able to tell as i cant afford to pay 50 bucks a dyno, and i dont think the shop will let me keep the car on the thing for me to wait for a new tune, than D/N it, than tey again im not made of money
Old Apr 29, 2008 | 01:24 AM
xCobalt05x's Avatar
just talk to vince about it before hand.... he will let you know if he can tune for it or not
Old Apr 29, 2008 | 01:27 AM
Jn2's Avatar
Jn2
how can i get a hold of him, pm me if you dont wann post it publically
Old Apr 29, 2008 | 01:34 AM
elecblue06's Avatar
looking forward to seeing what you put down on this ssetup man.. this should be fun.. i wish i had the money to put into my car like you do..
Old Apr 29, 2008 | 01:56 AM
xCobalt05x's Avatar
thats what re-enlisting in the navy in a technical rate gets you... money
