SS Valvecover
SS Valvecover
Does an SS/SC valve cover fit? The bolt pattern looks to be the same. I like the looks better, and I was going to buy an extra one to paint anyways. Should I buy an SS one?
http://www.j-body.org/forums/read.ph...66971&t=166971
Sort through this thread but he is using an LSJ valve cover on an L61 and he found a gasket to work.
than it would fall into wether the ignition coil from your stock set up will bolt onto the SS valve cover...but im sure you can rig something to make it work, there isnt any high pressure in the valve cover...
Staged07SS
Aug 19, 2015 07:11 AM
