Stage 3 Comp Cams....Anyone done it???
Old Feb 13, 2010 | 03:00 AM
  #151
xxxxsh4d0wxxxx's Avatar
Originally Posted by NightHawk
dan is pretty busy, should have pics online though
as far as changing it, we talked about that today haha. he said that they werent really selling any of the first model just because they werent deep into the balt market yet. he tossed the jig for it and then a few years later when they decided to start making it again, they redesigned it a bit. he said it should give any diff in performance as far as changing it up. no fitment issues with it and its performed great!
Last time we talked, they were changing servers for their website, and they haven't gotten around to transferring pictures yet.
It shouldn't give any difference in performance?.. They didn't even dyno it?
I would assume there would be a difference in performance.. It was a totally different design..
Old Feb 13, 2010 | 03:10 AM
  #152
NWAE Cobalt's Avatar
not a totally diff design, just that the pairs of headers were swapped.
they didnt dyno it back then cause no one was buying parts on the scale they do now haha
and you are correct, i miss spelled, it SHOULDNT give any difference
Old Feb 13, 2010 | 09:07 AM
  #153
huckernage's Avatar
Originally Posted by xxxxsh4d0wxxxx
Who goes above 6,000 RPM daily, though?
Originally Posted by huckernage
everyday not everytime, even 7500 on stg2 cam.
everyday I do it over 7000 but not everything i go that high.
Old Feb 13, 2010 | 10:25 AM
  #154
I thought you would yield more power, pairing the firing cylinders in correct order like the older model.
My limiter hits at like 7,000.. Or whatever it is for the stock 5-speed..
Not for much longer though!
Old Feb 13, 2010 | 10:48 AM
  #155
stock limiter is 6.5k
hucker and i both are up at 7.5k lol
as far as pairing the cyl, from what i have gathered while talking with them, it doestn really seem to matter much at all perf wise. im sure you do gain an adv one way or the other, but not enough to really matter. the one i have is the original design
Old Feb 13, 2010 | 11:05 AM
  #156
huckernage's Avatar
who will be first at 8100 with valvetrain and neutral balance shaft.
Old Feb 13, 2010 | 11:13 AM
  #157
screw neutral balance...im going NO balance shafts hahah, getting the delete kit.
im not doing that now though, have to refocus some energy from the car to getting some bills taken care of and some college work done.
and really...we dont make ENOUGH power up there to really justify it without ALOT of other mods to make it worthwhile
i certainly wont do either till my engine is pulled and built
Old Feb 13, 2010 | 11:17 AM
  #158
07cobaltguy's Avatar
oh god what is with you guys and the balance delete kit? I rode in a lsj with that and i think i lost some fillings. The vibrations are about the equiv of welding your motor straight to your frame with no bushings.
Old Feb 13, 2010 | 11:46 AM
  #159
huckernage's Avatar
do you have some video of that.
no delete for me
8100 it my dream. here my scenario.
1-7800
2-8000
3-7700
4-7200
i ll finish my ź in ž of my third gears.
now at 7500, i m limit to finish it in third gear
Last edited by huckernage; Feb 13, 2010 at 11:46 AM. Reason: Automerged Doublepost
Old Feb 13, 2010 | 11:48 AM
  #160
unfortunatly i dont. we dont associate with him anymore. but the car was just brutal to ride in. the vibrations were absolutly nuts, and uncomfortable.
Old Feb 13, 2010 | 11:59 AM
  #161
huckernage's Avatar
you mean with a delete shaft cause neutral is just on idle you feel it.
tell me about his support. trans and motor were stock?
Old Feb 13, 2010 | 01:04 PM
  #162
i have poly trans mounts, solid engine mount, cams, and am lowered pretty far...car vibrates like crazy as is
Old Feb 13, 2010 | 03:15 PM
  #163
he was januarys COTM.
Old Feb 13, 2010 | 11:50 PM
  #164
I thought it was higher than 6.5k.. I hit it the other day on accident..
WOT + cold street = OOPS!
I see no reason for the balance delete kit, or the neutral kit. Not for us anyway.. LSJ/LNF, sure.
Old Feb 14, 2010 | 02:05 AM
  #165
it makes sense cause you can then rev out to 8k plus and for cams, that can be AWESOME!
as for the 6.5k...it makes sense to leave it there unless you need it higher....
and as for my setup...its pending pymnt/ delivery....so pretty much sold already :P
Old Feb 14, 2010 | 08:58 AM
  #166
Very nice! When tuned by Trifecta, will the rev be raised?.. I'm always afraid to hit it, can't really be good for the car as that's basically the motor saying okay the internals can't handle much more, we're going to cut you off now.
I'm sure there is a bit of lee-way, but I'm no expert.
Old Feb 14, 2010 | 03:10 PM
  #167
huckernage's Avatar
yes it up to you. 5900-6666-7200-7600. you choice it.
hit it at 6500 not that bad. hit it 7500 not good but **** happen.
- when i suggest a rpm setpoint i always put higher that he ask for.
if i put yours at 7500 and you always shift at 7100 you wont never hit it and have some fun.
Old Feb 15, 2010 | 12:51 AM
  #168
but you MIGHT hit it and thats the problem
if i were you i would say set it at 7100rpm ish
Last edited by NWAE Cobalt; Feb 15, 2010 at 12:51 AM. Reason: Automerged Doublepost
Old Feb 15, 2010 | 01:12 PM
  #169
Yeah, I want it raised a little so I can have some fun, but not in the area for destroying ****.
Is it possible to break anything hitting the stock limiter?.. If you bump it up then you're pushing the motor farther than it was intended, and sure to break something.
On a side note, NightHawk: I honestly think a 3" cat-back is too big.. I wouldn't use anything over 2.5" for N/A.. Even WITH cams.
My 2˘
My reasoning: To reduce additional backpressure, the OEM exhaust tubing can be replaced with madrel-bent tubing of the same size or one size up from the OEM. As a general rule, you can enlarge the pipe diameter of your OEM exhaust system by 1/4- to 1/2-inch to increase your horsepower. However, any additional increase in pipe diameter is likely to decrease your performance; specifically, low end torque.
Bigger is not always better.
Up to 250 Horsepower is best served by a 2 1/2" exhaust.
I'm not saying anything bad against you, I'm just throwing it out there. I got it from the MagnaFlow website.
Last edited by xxxxsh4d0wxxxx; Feb 15, 2010 at 01:19 PM. Reason: Automerged Doublepost
Old Feb 15, 2010 | 07:09 PM
  #170
well very soon i will be over 250whp and i have a 2.5" muffler to create the backpressure
and ya, i understand :P
Old Feb 15, 2010 | 08:07 PM
  #171
i run my car out to 7k have yet to have issues. The L61/LE5/LSJ/LNF all have the same valve springs. lsj's regularly run out to 7400
Old Feb 15, 2010 | 09:59 PM
  #172
Going forced induction?? I was randomly reading up.. And these guys on this Camaro are saying that 3" is too big for even 300 WHP. Good for high-end though!
Although, if you have the right size primaries then the system behind that really shouldn't cause to you lose too much.
Really? I didn't know that.. +1 for information!
Old Feb 16, 2010 | 04:48 PM
  #173
right, valve float is at 7500rpm
and no, staying n/a for my build...
Old Feb 16, 2010 | 09:38 PM
  #174
huckernage's Avatar
wtf tommisssss
will you grind a stg 10 cam somewhere to get around 250
you dream in color lol
Old Feb 16, 2010 | 09:40 PM
  #175
nope...250 wont be now, but son enough....
lets just say....n/a allllll motor!
