stand alone's
Old Jul 27, 2007 | 08:59 PM
BLKLS's Avatar
stand alone's
is anyone out there running a stand alone on the 2.2? if so what have you got, what other mods are you running, and what kind of power gains did you see after dropping the stock ecu?
Old Jul 27, 2007 | 09:09 PM
victory_red_SS's Avatar
LSX RWD S/C conversion
The trouble with using a stand alone, besides cost, is the ability to retain the stock functionality of your cars creature comforts, p/w, p/l, stereo, AC etc, etc.
Old Jul 27, 2007 | 09:23 PM
NJHK's Avatar
Exactly.
Old Jul 27, 2007 | 09:36 PM
BLKLS's Avatar
so asuming from that state ment these cars are can network'ed arn't they
Old Jul 27, 2007 | 09:38 PM
exiged's Avatar
well what about an ls with manual windows and locks.
Could we use say... the AEM EMS?
Old Jul 27, 2007 | 09:43 PM
NJHK's Avatar
I was under the impression that it ran off a motor and not the computer...
Old Jul 27, 2007 | 09:47 PM
exiged's Avatar
i actually have no idea, i was just looking at it on there website.
actually heres a copy and paste off there page:
AEM's Plug & Play Engine Management System (EMS) plugs directly into a vehicle's factory ECU harness and requires no additional wiring or hardware. Windows™ compatible software (2000, XP, NT, 98, 95, ME) makes the task of copying, viewing and manipulating data as simple as a click of the mouse. An integrated tuning wizard allows users to create a base map specifically for a car’s configuration, regardless of what type of injectors, sensors, coils or other changes have been made. The AEM EMS's infinitely adjustable software allows tuners to program virtually any combination of engine control, power adders and auxiliary devices, and accurately delivers proper amounts of fuel and correct ignition timing for any boost level or operating condition.
Soooo..... maybe this could help with boosting a 2.2?
Old Jul 27, 2007 | 09:48 PM
IonNinja's Avatar
the only standalone I am familiar with being run on the Ecotec is Megasquirt.
you can set it up so that it controls only your fuel injectors and let your stock ECM handle ignition or you can switch to a diff ignition setup and have full control over timing and fuel...this way will allow the stock ECM to control all the other factory settings as normal.
Old Jul 27, 2007 | 09:55 PM
exiged's Avatar
really i thought i heard somewhere sometime megasquirt didn't work on a cobalt.
What i really want to know is can these maybe help with boosting my ls???? lol.
Old Jul 27, 2007 | 09:58 PM
If someone is serious about going stand alone, they can re-wire all the creature comforts, to run independant of the pcm/bcm's, but that add's to the overall cost.
This is the route we are taking with my car but with everything stripped out anyways, I am already halfway there.
Old Jul 27, 2007 | 10:37 PM
BLKLS's Avatar
hmmmmm.....i need to get a manule, and a wiring diagram...
Old Jul 27, 2007 | 11:09 PM
elvisc's Avatar
jesus guys
standalones are universal.
you can make the megasquirt work, and the aem....etc
you leave the stock computer to do the a/c and such, the standalone only controls the fuel and spark
Old Jul 27, 2007 | 11:53 PM
Originally Posted by elvisc
jesus guys
Old Jul 28, 2007 | 12:31 AM
IonNinja's Avatar
I would speak with Elvis if you need help boosting with standalone tuning...he is in the process of setting up megasquirt on his fully built motort.
btw with standalones there is no specific applications, just certain cars have wiring harnesses available for them. so if you're going standalone you've got quite a bit of wiring to do. trust me if you check the docs on megasquirt, there is a lotta **** you have to take in.
Old Jul 28, 2007 | 12:34 AM
NJHK's Avatar
jesus guys
You are correct but I was under the assumption he wanted to use a full standalone replacement, hence why he said "dropping the stock ecu".
Old Jul 28, 2007 | 09:53 AM
elvisc's Avatar
DERRRRRRRR
yea i am right. To run a standalone all you need to control is the spark and fuel.
Fuel injectors plugs straight into the standalone and the ignition could either be ran by the stock Crank position sensor (which won't work on the 0x-04) or you could mock up a crank wheel, which is picked up by a VR sensor, then sent to a module (like the EDIS-4) then a signal is sent to the standalone and then the standalone sends back what degree of spark for thet position of crank to do.
Yes there ARE plug and pray standalones but they all work the same way, just some have more features...etc
And for boost you should ALWAYS use Speed Density. (MAP vs RPM)
TPS, CLT, IAT are used for enrichments (Accell enrichments, warm-up, crank...etc)
Fuel is tuned first by the VE tables with no corrections then you enable EGO (o2 sensor) feedback to do corrections (>70% throttle or whatever you set it to)
Old Jul 28, 2007 | 01:20 PM
FastPace Motorsports's Avatar
Why not run a piggy back system?
Old Jul 28, 2007 | 02:57 PM
elvisc's Avatar
because what you're essentially doing is tricking the car it's in a different field of it's VE table to shoot as much fuel as you want.
for N/A piggybacks are great, but for boosted cars i would use a standalone.
Old Jul 28, 2007 | 03:26 PM
exiged's Avatar
sooo.... if essentially these are universall then why has nobody mentioned or thought of using one to boost a 2.2??
Old Jul 28, 2007 | 03:31 PM
Now, isn't that a great question???
I checked into the stand alones for my project and the same result kept coming back, trouble retaining stock functions not related to fuel management.
Old Jul 28, 2007 | 03:37 PM
exiged's Avatar
Do you know exactly what stock functions you lose? i'm assuming anything controlled by the computer right?
Ive got pretty much as base you can get of a 2.2, manual everything, with an aftermarket stereo. The only thing i could think of off the top of my head that i may lose, would be the DIC, but still, thats mostly mileage and such, and i always leave it on coolant temp ...its just something like to watch...
well now that i think about it maybe a/c too... but yea what standalones did you look into?
Old Jul 28, 2007 | 03:44 PM
Fast, MSD, AEM and Bigstuff3. The companies all told me the same thing, except BigStuff. to kiss my stock functions goodbye.
The BCM controls most of the electrical components but the PCM controls the BCM.
The Bigstuff will work but it is piggybacked in so as to only control the fuel management.
Unless the tech's at the companies don't know their products, they told me their products wouldn't allow what I wanted.
The alternative is to have everything re-wired so that everything besides fuel management, is run independantly of the stock computers. This is the option we have chosen to use.
Old Jul 28, 2007 | 04:00 PM
elvisc's Avatar
lol what!?
the stock computer wont be controlling the fuel injectors + spark, it doesn't have to do with anything else.
nothing is piggybacked, it runs your engine on its own. Your stock computer will handle a/c and all of that jazz.
im using a standalone for my 2.2 eco
Megasquirt w/ 42# injectors (high imp), and then i'll be implementing the Ford EDIS-4 for spark.
Old Jul 28, 2007 | 04:02 PM
BLKLS's Avatar
are you saying we don't have a crank sensor? i haven't looked....
originaly yes but ti sounds like that wouldn't work. what if i wanted to make up a harness that went in line with the factroy ecm harness but took all the ignition and fuel controls to say a aem box and left all other functions run back to the stock ecm that wouldn't work?
Old Jul 28, 2007 | 04:03 PM
lol what!?
You really need to set those tech's straight because they obviously didn't want my business bad enough to know how their products work.
