supercharger
Old May 1, 2011 | 08:53 PM
osteen08's Avatar
supercharger
would a 2.2 in an 06 cobalt lt be able to house a turbo styled supercharger?
Old May 1, 2011 | 09:28 PM
HyperMuffin's Avatar
You mean a procharger?
Old May 7, 2011 | 03:31 PM
osteen08's Avatar
yeah.
Old May 7, 2011 | 03:33 PM
07BoostedG5's Avatar
I only know of one and hes here in Houston, hes not on the forums, and I know little details other then yes its possible. It was on a lsj not that it makes much of a difference.
Old May 7, 2011 | 06:50 PM
IonNinja's Avatar
elecblue06 had a centrifugal blower on his LE5 Ion. It can work, just need the right mounting bracket
Old May 8, 2011 | 04:18 PM
Jn2's Avatar
Jn2
Elecblue had one on his 2.4, don't c y u couldn't get one...u just need th right bra kdt and.belt set up....
Old May 8, 2011 | 10:40 PM
Nighthawk243's Avatar
It'll work, but it isn't exactly an optimal/cost effective setup.
Old May 9, 2011 | 12:09 AM
Would be more wise to just turbo it.
Old May 9, 2011 | 12:16 AM
kikal8's Avatar
ya agreed. i find it dumb to do it that way. itll be hard as **** to get setup right.
Old May 9, 2011 | 05:33 PM
osteen08's Avatar
right now im looking at about $3500 for a procharger c1. could anyone list all the internals that are made for the 2006 2.2l. i cant find the one that has the list for the aftermarket head, pistons, and everything.
Old May 9, 2011 | 07:34 PM
osteen08's Avatar
ok one more question? whats the difference between the 2.2 L61 and the 2.2 LAP? this is my first cobalt and its an 06 lt.
Old May 9, 2011 | 08:26 PM
you have the L61 with an 06
second of all is it your daily driver? and 3500 sounds a little cheap honestly for a procharger setup
Old May 9, 2011 | 08:46 PM
redcobalt07's Avatar
Turbo style supercharger lol
Old May 11, 2011 | 04:39 PM
osteen08's Avatar
ok thanks. and its just the c1 procharger and the intercooler and everything but the brackets. thats not installing it or or rebuilding the motor. and no its not my daily driver.
Old May 11, 2011 | 05:15 PM
Hockeyman's Avatar
go straight turbo, less fabrication involved, cheaper, and more potential power.
Old May 11, 2011 | 05:55 PM
ok, you wanted a procharger system, not a twin charge system, that has the turbo feeding a supercharger like the eaton m62.
3500 is too much for just a supercharged system, zzp has a kit for 2275 (right here Cobalt & Ion ---> ZZ Performance) thats designed for the cobalt, you just have to go through trifecta for the tune (you'll be adding like 80-100ish whp with the stage 2 from what they say) then you can do a full exhaust headers back for less than the 1225 difference.
or zzp offers a turbo with different stages (here from 2k to 3500 depending on the stage) again designed for the 2.2/2.4 cobalt engine.
Hockeyman a turbo set up is less fabrication work then supercharged set up in my opinion
Old May 12, 2011 | 05:57 PM
osteen08's Avatar
i know what yall mean but ive seen an auto with a turbo get beat by a auto with a procharger. both of them were built the same way with the same components and the procharged one won by 5 links in the 1/4
Old May 12, 2011 | 06:58 PM
and that was the only difference between the two cars?
they had the same tire set up, same weight, same exhaust, same engine mounts, tran mounts?
Old May 12, 2011 | 07:42 PM
osteen08's Avatar
idk about all that but they were built to compare the 2. and something else. i was on youtube looking about and i seen a cobalt ss twincharged? pushing 440 hp. what the hell is twin charged? sorry if it sounds stupid but ive been 4 wheel drive my whole life and wanted to try something else
Old May 12, 2011 | 08:37 PM
06_cobalt's Avatar
Procharger is a brand. Lol. The correct term is centrifugal supercharger.
Old May 12, 2011 | 08:39 PM
06_cobalt's Avatar
Where they use a blower and a turbo
i.e. the Cobalt SS retains the stock supercharger and adds a turbo.
Old May 12, 2011 | 09:38 PM
osteen08's Avatar
Would a rebuild be necessary for the 2.2? I know they have a kit for the 2.2 with an eaton supercharger but how do they bolt in a turbo?
Old May 12, 2011 | 09:43 PM
06_cobalt's Avatar
The supercharger bolts on the intake side of the engine and the turbo bolts to the exhaust side. If you did it on a 2.2 I would assume you would have to build the engine. But then again, I don't know if anyone has twincharged a 2.2 before. If I were you and you were dead set on it I would talk to ZZP about it cause they could help you more.
Old May 12, 2011 | 11:28 PM
osteen08's Avatar
Ok thanks. Cuz after seeing that one I'm setting my goals for it.
Old May 13, 2011 | 04:10 PM
SmackinJuice's Avatar
Sell your car and get a SC or TC; it'll be cheaper in the long run.
