supercharger
i would build that 2.2 first before even thinking of doing a twincharge set up. the moment u turn on that thing, on stock internals even on low boost it will just crack the life outta that motor in half. ZZP is where u want to start looking for all your stuff before big power adders to ur 2.2 specially if u want to make big power.
If you want a centrifical supercharger build your internals, get cams that rev high (that is where you will make power with this sort of setup, but make sure it is a supercharger grind), there is another brand that is good besides procharger. Check out a vortech setup thay have a v5 and a v9 which are for smaller engine bays, but are not self contained so you will have to tap the oil pan. Just know that you will have lots of custom parts which can be more expensive. Good luck with the build.
z28addiction
Sep 28, 2015 12:03 AM
