Supercharger problem
Old Oct 18, 2012 | 05:20 PM
GoofyBalt's Avatar
Im installing the alternator bracket and the tensior pulley on it is hitting the motor mount.. Did i need the LSJ motor mount? I read quite a few threads seems no one else had this problem.
Old Oct 18, 2012 | 05:21 PM
Pedobear's Avatar
some people IIRC had to grind a bit on the 2.2s
Old Oct 18, 2012 | 05:26 PM
GoofyBalt's Avatar
damn maybe i do then, it would be more than a little bit though. More like alottabit
Old Oct 18, 2012 | 05:55 PM
nhanson's Avatar
You installing the correct way?
The only thing you should grind is the head where the tensioner PULLEY comes in contact.
Get a picture?
Old Oct 18, 2012 | 05:57 PM
GoofyBalt's Avatar
No pic sorry, I have the 2005 and i looked up other peoples motor mounts and mine is way bigger. I know im installing it right ive looked at tons of pictures and my alternator bracket tensior pulley is hitting the motor mount bracket thats on the engine. I think i need the other motor mount or i need to cut mine way down.
Old Oct 18, 2012 | 06:03 PM
nhanson's Avatar
Try new mount before cutting IMO
Old Oct 18, 2012 | 06:06 PM
Pedobear's Avatar
pics please
Old Oct 18, 2012 | 06:43 PM
GoofyBalt's Avatar
Yep found a post defintely gotta by the update motor mount i cut mine and the belt rubs on it.
Old Oct 18, 2012 | 07:17 PM
CheatingSolitaire's Avatar
On my ion I had to cut the entire third bolt off that motormount iirc. Doesn't really affect anything, just the cost of doing business!
Old Oct 18, 2012 | 08:28 PM
GoofyBalt's Avatar
yea i did that and it still rubs so i ended up getting the bracket and motor mount that i needed for $50
Old Oct 18, 2012 | 08:39 PM
Pedobear's Avatar
O.o
Old Oct 22, 2012 | 04:39 PM
bluebalt07's Avatar
I'm kinda late to the discussion but yes the motor mounts on the 05-06 base models do not work with the sc set up. 07+ is a different style and works fine
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
z28addiction
Sep 28, 2015 12:03 AM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
