Supernovanator's "what did I get myself into" build thread
Old Feb 22, 2015 | 07:58 PM
Spawne32's Avatar
ill measure the ones i have in the garage tonight and get back to you
Old Feb 22, 2015 | 08:08 PM
Jesse's Avatar
Thanks! I found some other ones too. First are the 48mm ones:
Second is the other, 60mm ones I found.
Old Feb 22, 2015 | 08:23 PM
Spawne32's Avatar
measured 60.5mm with the caliper gauges so looks like the 60s are the way to go.
Old Feb 22, 2015 | 08:49 PM
Jesse's Avatar
Awesome. Much appreciated. These are the one's I'll probably be going with then. 52lb @ 43.5psi
http://www.ebay.com/itm/310971490732?_trksid=p2060778.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Old Feb 22, 2015 | 09:39 PM
Spawne32's Avatar
I'd stay away from ebay injectors, you never know if they are legit or not IMO. You can buy any size bosch from fuel injector connection or i can probably get you injector dynamics injectors for a good price. Im asking my guy now.
I believe I also have the programming information for the ID 725's and 1000's on my computer as well for HPtuners.
Old Feb 22, 2015 | 09:58 PM
/\ in for that, i gotta find some 1000s or 1200s
Old Feb 22, 2015 | 10:07 PM
07blackg5's Avatar
Slobodan Milošević
I snagged advises id1000s
Old Feb 22, 2015 | 10:18 PM
Spawne32's Avatar
Ill PM you soon as I have pricing, gonna try to get a cheaper rate for CSS members. He has the 725's for $350, and 1100's for 475 on his site but I might be able to get a cheaper rate. He also has pricing through FIC for the bosch injectors, will get prices on those.
Old Feb 22, 2015 | 10:26 PM
sandman's Avatar
my stock injectors measure 66mm from oring to oring
07blackg5's Avatar
Slobodan Milošević
inside to inside?
Old Feb 22, 2015 | 10:27 PM
  #36
Spawne32's Avatar
are you measuring on the oring itself or edge to edge of the body.
Old Feb 22, 2015 | 10:39 PM
  #37
Jesse's Avatar
Will actually be buying them directly from a bosch dealer. No worries there, just need injector data. $150-175 is a lot better than $350 or $475.
Old Feb 22, 2015 | 10:49 PM
  #38
sandman's Avatar
middle to middle. Bottom of seat to bottom of seat (closest parts of seats being together) was 63mm
Old Feb 22, 2015 | 10:56 PM
  #39
Spawne32's Avatar
interesting, which injectors were you measuring?
Old Feb 22, 2015 | 10:58 PM
  #40
sandman's Avatar
my stock ones i have sitting in my room
Old Feb 22, 2015 | 11:27 PM
  #41
Jesse's Avatar
That's odd. Care to post pics? Doesn't matter much to me now except for the sake of research. I know there are 485mm and 60.5mm. It was one of the two that I would need to use for my application.
Old Feb 22, 2015 | 11:50 PM
  #42
sandman's Avatar
Old Feb 23, 2015 | 12:17 AM
  #43
Spawne32's Avatar
oh your using a ruler :p
Old Feb 23, 2015 | 03:03 AM
  #44
Jesse's Avatar
So I was able to get some decent injector data thanks to some HPT forum help. Those 52lb injectors are probably going to happen after all. I just need the cash. Dual spray and they will flow 58lbs at stock 58psi rail pressure. Not bad at all.
Old Feb 23, 2015 | 09:17 AM
  #45
sandman's Avatar
hey man I used this as a precision measuring device to measure CNC tools at work. It s very accurate! hahaha
Old Feb 23, 2015 | 09:18 AM
  #46
sandman's Avatar
I noticed that the 52 was rated at 43.5 psi. I have a spreadsheet somewhere where you plug in injector rating and rail pressure to get injector numbers to put into HPT it was very handy for me.
Old Feb 23, 2015 | 09:21 AM
  #47
Shoot me a pm too, I've got a local wanting to go up from 42s but I want him to keep the dual spray pattern.
Old Feb 24, 2015 | 10:17 PM
  #48
Jesse's Avatar
I have a spreadsheet from Dsteck on HPT that does that and also calculates offsets and all the other **** but it is touchy. I'm getting negative offsets at higher rail pressures. Normally I wouldn't mind but it just doesn't feel right.
Old Feb 24, 2015 | 10:30 PM
  #49
sandman's Avatar
thats quite odd lol. the one I have doesnt do that
Old Feb 24, 2015 | 10:37 PM
  #50
Jesse's Avatar
Well then again mine is a sheet for transferring ford injector data into GM injector data.
