technical help on cams.
Old Mar 13, 2008 | 12:15 AM
MadBrad's Avatar
Now I know about the crank position on my07. Has anybody come up with any possible theories that might allow us guys to change the cams on our engine. Because have heard that even some of the LS engines have a crank position sensor. And they have ways of changing the cams out. Maybe a longer shaft or something to make the sensor sit right on top.
Old Mar 13, 2008 | 03:07 AM
jperris's Avatar
nothing yet, still waiting on a set of cams i ordered from TTR a week ago. the exhaust cam should be a direct swap. i'm going to compare the differences in the intake cams and see if it's feasible to transfer the 4x reluctor for the cam sensor.
Update: Got a box from CompCams today. I ordered the stage 1 n/a cams. If I have time at work, I'll take my valve cover off and compare. Interesting to note, the cams are ground on GM cores.
Old Mar 13, 2008 | 02:20 PM
MadBrad's Avatar
keep me updated. If thangs don't get to complicated. I might be spending a weekend in grease.
Old Mar 13, 2008 | 11:40 PM
Red07SSNA's Avatar
Do you have the timing chain holding tool -- and did the CompCams have good directions on swapping out the cams?
Old Mar 14, 2008 | 03:14 AM
jperris's Avatar
so i took off my valve cover off tonight, in order to compare the early-type cams with the ones in my car. pic below illustrates the differences. The yellow line on the early-style cam approximates the length to which it would have to be cut in order to fit in the head. The red lines indicate where the diameter of the cams get larger, both do it in the same area, but it seems the later cam flares out a little more than the early cam does, meaning metal would probably have to be added in order for the 4x reluctor to fit correctly on the early cam. So basically it won't fit without a lot of work. I think we're better off either getting the stock cam reground and finding a way to compensate for a smaller base circle, OR *crosses fingers* maybe somehow convince GM to get us some late L61 intake cam blanks. All in all, I'm a bit disappointed, but hey the exhaust cam is still a direct replacement, and (according to some simulations i've run) just replacing the stock exhaust cam with the comp stage 1, should be good for about 15 flywheel horsepower, along with a rough idle. Anyway, I think i'm going to hold off on installing anything until I get a solution figured out for the intake cam.
Old Mar 14, 2008 | 01:10 PM
TurboTechRacing's Avatar
Great post
Old Mar 14, 2008 | 01:50 PM
MadBrad's Avatar
I was thinking that maybe someone could machine an adaptor that could fit over the intake cam. I have full acess to CAD programs. If someone could get me the specs I can draw it on a program called soild works. From there I might, that is might be able to get the machine shop at my work to bulid the adaptor.
Old Mar 14, 2008 | 04:42 PM
We use solid works, save it as an "IGES" file extension and we can import it into our NC programing software and machine it
I think that would be a good part to "EDM" cut so it is very precision. Only factor is getting the timing gear aligned right, to the lobes on the intake cam....
Old Mar 15, 2008 | 05:28 PM
MadBrad's Avatar
Ture. That why I need some specs and detail between the stock intake cam and the aftermarket intake cams. The sooner somebody or I get the specs, than the faster I can make the drawings. Everything to lift of the stock to the lift of the comp cams. And how much needs to be trim. Because I have two different ideas. Either A clamp style or a cap style.
Old Mar 15, 2008 | 10:28 PM
Keep us updated, and we will make anything you need to get the job done
Old Mar 16, 2008 | 05:55 AM
jperris's Avatar
Originally Posted by Red07SSNA
...did the CompCams have good directions on swapping out the cams?
the directions included with the comp cams are generic; they pretty much outline the cam replacement procedure as it applies to a small-block chevy V8.
Let's find someone that's got an extra '07-up L61 intake cam laying around. Or, you can order one online for about $60+ shipping and get your specs from that. Part number is 12590699 for the stock cam.
06MetallicBalt
Jul 20, 2025 08:47 PM
S1000rrsteve
Aug 24, 2015 02:00 PM
spooler
Aug 6, 2007 05:39 PM
