For those with badmab header...
Old Mar 5, 2013 | 01:18 PM
dsmnutz's Avatar
Which o2 bung are you using for the primary sensor? The one in the header itself, or the one in the downpipe?
Old Mar 5, 2013 | 01:24 PM
yellowsupercharged06's Avatar
if i recall.... the header bung is for the primary o2 sensor, and the extra bung in the dp is after the cat for wideband.
Old Mar 5, 2013 | 06:59 PM
dsmnutz's Avatar
Right now (stock) both of my sensors are in the downpipe. The zzp downpipe I bought also has two bungs(like the stock one). So after installing the header and downpipe I will have an extra bung. Trying to decide which one to plug...
Old Mar 5, 2013 | 07:02 PM
chevygirl2006's Avatar
I'm using the one on my downpipe.
Old Mar 5, 2013 | 08:03 PM
nhanson's Avatar
Put your front O2 in the header.
Old Mar 5, 2013 | 08:08 PM
southal cobalt's Avatar
you cannot possibly screw this up, unless you just leave out the primary 02 sensor. the layout of the badmab is exactly like the stocker
edit: exactly what ^ said
Old Mar 5, 2013 | 08:26 PM
dsmnutz's Avatar
My stock manifold does NOT have a bung...both sensors are in the downpipe. It will work in either hole, just wanted to know what others were using. I'm thinking primary in header and plug first hole in dp till I get a wideband.
Old Mar 7, 2013 | 01:14 PM
ml2242's Avatar
I have mine setup with my wideband in the manifold and the primary in my pre-cat downpipe bung. I'm not sure if this is the best way to do it but It works fine for me- wideband tends to jump around alot though....
Old Mar 7, 2013 | 04:17 PM
IonNinja's Avatar
^^^^^ Swap your wideband and primary o2 around
Old Mar 7, 2013 | 04:20 PM
SSCOBALTSS07's Avatar
Yea my stock manifold had one so I just switch ed
Old Mar 7, 2013 | 04:47 PM
ml2242's Avatar
Will this mess with my dyno tune? I paid way too much for the tune... and I'm not trying to re-tune anytime soon. LMK. Thanks!
Old Mar 13, 2013 | 02:40 AM
scagnetti76's Avatar
I Mis understood the question..
Old Mar 13, 2013 | 02:44 AM
Plug the one in the mani, and put wideband in the dp so it will read equal from all cylinders.
Jaredssbalt
Feb 19, 2011 11:35 PM
BADMAB
Canadian North Pacific
Jan 27, 2011 07:55 PM
Gestapo007
Oct 27, 2010 10:45 PM
undrgrndcobalt
May 4, 2006 07:58 PM
