Throttle Bodies?
have your tb ported pm me if u want it done. here is my dyno results before and after on an lsj but u get the idea. smoother slightly larger opening= more hp
https://www.cobaltss.net/forums/show...ight=headgames
LSJ TB on a bolted and tuned 2.2L is too much, and someone a few posts before beat me to it: "Going with to large of a throttle body will slow down air velocity killing performance. I wouldn't recommend anything larger then a 2.4 throttle body on a 2.4 intake manifold."
I don't mean to side track but how does your 2.2 auto run now that you're tuned? I have the same mods on my 2.2 auto plus the 2.4 tb and intake mani very soon. Just wondering how you like it and how much of a difference?
do it and don't look back. you gotta feel the dirfference for yourself.
On a bolt on 2.4 an LSJ tb will make slightly more power. On a 2.2 it is a bit too much.
So what you guys are trying to say is that the 2.2 will benefit from going from a 58mm throttle body to a 64mm throttle body but that the 2.4 wont benefit from going from a 64 to 67?
your going to tell me that on a tuned full exhaust intake 2.4 a throttle body thats 3mm bigger is too big? You do realize there was honda 4 cylinders with 60-62mm throttle bodies right? And those are the b16a2 and f20c. So they arent even their biggest 4 cylinders. Now your going to proceed to tell me a 2.4 making about 40hp more at the crank wouldnt benefit from 5-7mm more throttle body?
Velocity is more important then size of port/opening.
Please go read up on flow dynamics on an engine. Also consider how much surface area you add with 2 mm. Best thing you could do is take 2.4 throttle body and machine or port top half in such a way to make it a tapered throttle body which will help air velocity.
So therefore whats the issue? Theres a lot of variables to take into account yes. But also take into account a poor port job could introduce far too much turbulence as well. If its been proven to make a bit more power then thats enough said.
I actually understand that. But this has been shown to make more power on a 2.4.
We dont know if the cars lost tq down low or not yet as no ones dyno'd a 2.4 with the larger throttle body. But theres enough evidence to support that the 2.4 would be able to use the additional size. Its barely a bump up anyway.
