Throttle body spacers
yea... Edelbrock makes a 70mm Throttle Body Spacer but its undrilled soo ur gunna have 2 take it 2 a shop or do it urself...... here is the link
http://www.andysautosport.com/chevro...ody/edelbrock/
i was wondering if it helped in any way performance or otherwise but i might make my own.
i will probably wait to see if any one has done the mod succsessfully and made it work in some positive way.
i made one it wasent to hard out of 1 in thick t6 aluminum used hole saw then cut the ends off. and drilled and taped it but it was to thick for what i was useing it for. i ended up using 1/8 flat plate in sted.. with my stock tb for mateing it to a m62 from a 2.2.
Well wat a throttle body spacer does is its designed to increase speed and volume to the incoming intake air, and atomize the fuel more efficiently increasing HP, and MPG. A throttle body spacer is a fairly simple modification to add to your vehicle, installation time is less than 30 minutes with very basic hand tools. But thats if u dont have 2 drill your own holes... if u still decide 2 do this.. GOOD LUCK!
yes very much so.. but personally... i wouldnt do it... i would just get a bored out throttle body and b done with it... which i am goin 2 after i get my new intake manifold, i am gunna have 2 use a 75mm throttle body from an LS1 engine(corvette)
