Tire Pressure
Tire Pressure
What pressure do you 2.2 owners keep your tires at? I understand that higher than recommended tire pressure can aid performance, even tho it detracts from ride comfort. Also specify which tires you are running, the stock tires, Pirelli's, or aftermarket.
im running Kumho Ecsta ASX tires......the max psi on them is 50.....so im running 41....and they stick to the ground well and still ride fairly well.....i would reccommend getting aftermarket rims and tires.....the stock ones suck
Originally Posted by CobaltCowboy
how much do your wheels weigh, skottish?
stock is 35 psi for best blend of performance, wear and gas milage.
Any aftermarket rims would be custom to the tire you choose to put on them. For instance mine are max 44 psi, so I'm running 39.
DANRICKARD
Oct 1, 2015 12:08 AM
