Trifecta tuning question.
Old Jun 7, 2010 | 10:56 AM
COLER59's Avatar
*******need help*******
im about to order the trifecta tune that was just recently released for the l61 motor.
Current mod list is
obx-r longtube header
k&n typhoon short ram intake
full cat back exhaust.
Under drive crank pulley
2.4 intake manifold and after tune will add the 2.4 throttle body
the question i have is with the trifecta tune what are there cababilities. Can they remove the top speed govener, shift rpm, compensate from 15 inch tires and wheels to 17's
i added new wheels bigger and seems like the car has more torque but slowed down alot in first and second.
Im waiting n them to contact me for payment so a quick response would be awsome.
Old Jun 7, 2010 | 02:35 PM
rockstarbass1's Avatar
Yes vince can alter all that.... well I know for sure everything but the rim issue. Didn't have that done. But yes to top speed, he can raise your redline. And I think can change your shifts idk that also cuz I have a manual
Old Jun 7, 2010 | 03:21 PM
HyperMuffin's Avatar
Not sure if you would want to raise your redline very much, unless you have upgraded valve springs.
Old Jun 7, 2010 | 04:11 PM
s h a y n e's Avatar
lol raise it to 7500 at its fine wtf are you talking about hyper muffin
Old Jun 7, 2010 | 04:18 PM
Is your redline/shiftpoint at 7500? I highly doubt it. If maybe put it to 7k that might be alright but anything else is just pushing it and I bet something will break not long after.
Old Jun 7, 2010 | 05:41 PM
huckernage's Avatar
my setpoint is at 7500 and happy for it
Old Jun 7, 2010 | 05:50 PM
Jn2's Avatar
Jn2
yes he can do all that...
Old Jun 9, 2010 | 11:02 AM
COLER59's Avatar
Originally Posted by rockstarbass1
yes vince can alter all that.... Well i know for sure everything but the rim issue. Didn't have that done. But yes to top speed, he can raise your redline. And i think can change your shifts idk that also cuz i have a manual
i also have a manual trans....thanks for the quick replies
Originally Posted by hypermuffin
not sure if you would want to raise your redline very much, unless you have upgraded valve springs.
i usually shift at like 6500 to 6750, i just wanted a slight lift of my redline nothing drastic...and i do not have upgraded valave spring...hanks for the info though i dont want to break anything in this motor i have some big plans for it....im going to be contacting sam or nybull for more help
i just got a saturn ion redline motor complete given to me from a friend who just installed the gm crate motor with 305 hp plus he is doing more bolt ons to raise it to 400whp...
Thanks for all the help guys i called arron and the tuner is on the way should have it tommorow
i believe i will be one of the few to have a tune to the l61 motor..so ill let you guys know how it goes...i guess this tune was just recently released for this motor....
Old Jun 9, 2010 | 12:11 PM
Actually a tune for the L61 from trifecta has been available for a while now. Many L61's have been trifecta tuned. I just recently had my L61 tuned from trifecta and I am very pleased with the results and the great customer service with them.
Old Jun 12, 2010 | 06:00 AM
SmackinJuice's Avatar
Oh that huckernage! you forgot to add you have stage 2 cams with your 7500 redline.
unless you are using cams are cars powerband dies off before 6.5k, no reason to have your redline any higher.
http://www.crateenginedepot.com/stor...?Webpage_ID=67
use those dyno's for your own judgement. that's even with the 2.4 im before and after.
So don't listen to huckernage haha :P
Old Jun 12, 2010 | 09:59 AM
huckernage's Avatar
i was at 7500 rpm without my cam
before 7500 rpm setpoint i ran 15 flat
tuned at 7500 fisrt time at track 14,6
i finish my ź in third gear.
Old Jun 12, 2010 | 11:45 AM
this ^
Old Jun 12, 2010 | 12:46 PM
huckernage's Avatar
this ^
shayne u are automatique
check this out. i reflashed my fisrt auto
roll from 85km. i pull when he pull hard. i was in 3th gear
not bad for a automatique
http://www.youtube.com/watch?v=ejTHcNxqt9M
Old Jun 12, 2010 | 12:49 PM
rossshady120's Avatar
i had to raise my rev limiter from like 6k to 6700
Old Jun 12, 2010 | 01:36 PM
RecklessL61's Avatar
vince can tune everything you want and the reason it slowed down alot in first and second is becasue of the 2.4 mani, which the tune will fix if you have any questions you can pm my i will be happy to answer them
Old Jun 12, 2010 | 11:31 PM
did my dyno show nothin! huckernage your special ok! for 80% of the 2.2 on here they won't have any reason to go over 6500, even when you shift your still in your powerband.
i will agree that going a little higher will net you an extra tenth of a second, but you also took off a day of the car's life
of course this is just the 80% of 2.2er's, of course there will be exceptions.
Old Jun 13, 2010 | 12:17 AM
xxxxsh4d0wxxxx's Avatar
7K would be the MAX I would have it set at. You have no cam and stock valve-train.
You're not making any power past 7K. Actually, like aforementioned earlier, your power is probably dropping around 6.8K.
Old Jun 13, 2010 | 11:49 AM
blackbolt89's Avatar
ive got a 2.2 L61 and have been tuned for over a year. lol
Old Jun 13, 2010 | 12:40 PM
olivecj's Avatar
Damn man that 2.2 auto held in there really good. So you raised the rev limiter to how much? It looked like it was like about 7 grand. What was all the stuff you did to it. Only reason i'm askng is because in about a month i'm gunna order the trifecta tune for my g5 gt auto.
Old Jun 13, 2010 | 12:50 PM
huckernage's Avatar
7200 rpm tranny setpoint and 7250 rpm motor. they come in conflict when same setpoint.
TFT put tranny as firm as he can do.
you have to reflash your car twice PCM and TCM
tcm takes 45 secondes
pcm takes 13 minutes
CAI, intake 2.4, SC dowpipe, SC catback, stock exhaust manifold
Old Jun 13, 2010 | 12:51 PM
bryce712's Avatar
Current mod list is
2.4 intake manifold and after tune will add the 2.4 throttle body.
youll notice a nice difference with the TB on there after the tune.
Old Jun 13, 2010 | 04:40 PM
nice 2.2 auto so 7200 and 7250? and what does they come in conflict mean?
Old Jun 13, 2010 | 04:55 PM
huckernage's Avatar
if both are at the same setpoint. you can feel boucing. we that way, you are sure everything ll be fine
Old Jun 14, 2010 | 06:39 PM
INTENSEL61's Avatar
I will be Trifecta tuned within the next couple of weeks.
2007 Cobalt LS Coupe
- Automatic Transmission
- Injen Short Ram Intake
- 2.25 in. MagnaFlow Exhaust
- ZZP Mid Length Header
- 2.5 in. ZZP Stainless Downpipe
- 2.4l Intake Manifold
- Ported and Polished 2.2l Throttle Body
- Tenzo-R Lowering Springs
- Bridgestone POTENZA Tires
The Balt can move. I would used a 2.4l tb but haven't come across one with 6 pins. My ported and polished 2.2l tb will do just fine. I felt a nice gain after installation.
What are some of you guys predictions/recommendations on how my car with its current mods will respond with an aggressive Trifecta tune? Thanks!
Old Jun 14, 2010 | 07:34 PM
huckernage's Avatar
my prediction is:
bang in a wall because you are to exciting to be freshly tuned
recommendation:
do it right the ******* now.
