Tuned 2.2
Once tuning comes out for the L61, I know that quite a few guys will be going f/i. On behalf of those of us who are going to wait a little longer before we dig that deep into our pockets, I have a quick question: How much of a power gain are we looking at by tuning the 2.2 while staying n/a? I know that realistically, the results of tuning the 2.2 won't be earth-shattering, but I was just curious.
So, what do you guys think?
Lets say a fully bolted 2.2.
*cough* Theres always one in every crowd.
But seriously, how much more power is available for us guys that will be n/a for a while? I know it is hard to say because no one has done it yet, but someone must have a pretty good idea about it.
Sooo... anyone have gut feeling about how much more power can be extracted through a custom tune? BTW I know that peak power isn't the only thing that could benefit, but for the sake of discussion I wanted to start with that.
We have investigated this in the past. The LSJ and L61 engines are the most compatible, but the crank reluctor ring trigger is an issue.
For these engines, the benefits versus cost simply doesn't make sense.
there is a local guy who pwnds stg 2 cobalts.. buy 3- 4 cars...... with the same kit
yep.... at 45 when he sprays.. nd it shifts down to his passing gear he lights them up nd all u see is smoke from his tires its baller.. he has beaten an ass load of cars...... that he shouldnt........
I know Im getting on this a bit late and Im probably gonna get flamed to crap for this but, a friend of mine with a civic running a 2L n/a puts down 250whp. Mind you this motor is Piston/Rods/Cams/Valves/Springs/Porting/Ballanced.... Basically all but sleves. Tuned with hondata.
Id guess that for one of us to put down simiar #'s in an n/a 2.2, similar modifications would also have to be done. Running an oe bottom end with a well built head/cams/valvetrain (Higher compression?) & feul system 200 dosent seem unreasonable. On a tune of course.
Are there any resident engine pros that would agree or disagree with this?
I don't think you'd reach those power levels on a stock bottom end. Those Honda guys run crazy high compression with those N/A builds. That mixed with a lotta RPM's is what makes them power but the motors are so peaky with that. All top end...
For a strong N/A build I think you'd have to be running atleast 11:1 compression to pass 200whp
