Turbo
Old Oct 9, 2014 | 09:14 AM
no_ss's Avatar
Turbo
Is the cobalt compatible with the turbo kit w/intercooler in an srt4?
Old Oct 9, 2014 | 09:48 AM
Spanky's Monkey's Avatar
You trollin no_ss? I'm sure with some time, patience and more money then you wanna spend you can make it work but there are serious factors involved. The piping is not gonna line up so you're losing money there best to look into LNF piping. Things like the intercooler can always be fab'd to work but it makes more sense to get an LNF intercooler and pipe kit. You will need a turbo manifold designed for the cobalt and the likely hood of the SRT turbos inlet/outlet angles lining up are slim. The issue of the turbo fitting properly is gonna play a huge role in piping fitment as well. Don't forget about the oil feed and return setup on the SRT turbo, this alone can make a custom setup a nightmare. In the end you're better off with an LNF swap or a custom kit like ZZP. Not to mention the stock Neon SRT turbos were intergrated into the exhaust manifold and that setup just wont fit the cobalt, period, so I am assuming you are looking at an aftermarket SRT kit. Good luck with this if you're still willing to go through with the build. Could be fun if you don't mind the stress involved.
Old Oct 9, 2014 | 09:50 AM
umrdyldo's Avatar
OP, the answer is: Don't even waste your time.
Old Oct 9, 2014 | 10:30 AM
no_ss's Avatar
I'm not trolling it's just that someone asked me if it would fit into my car, I guess he was tryin to get at maybe I could look for a kit in a salvage srt maybe because it would be easier and cheaper to find but I guess I'll have to just look into the lnf.
Old Oct 9, 2014 | 10:35 AM
LNF turbos are dirt cheap on here and ZZP has em for a great price too. Just make sure you get one in working order that hasn't been beat to ****. I would suggest avoiding the ones that have been overboosted prior to removal. I have noticed those turbos tend to give out a lot quicker then the milded booted stockers. If the previous owner pushed 26psi through it I wouldn't want it.
Old Oct 9, 2014 | 12:31 PM
Blowncavy's Avatar
Haha man this is funny
Old Oct 9, 2014 | 12:53 PM
Sl0wbaltSS's Avatar
Troll. inb4
Old Oct 9, 2014 | 05:44 PM
no_ss's Avatar
Troll. inb4
God damn, ya boy is just trying to learn and find out my options.
Old Oct 9, 2014 | 06:21 PM
Blowncavy's Avatar
All good. My opinion would be to do as much looking and reaseach as you can.
Ecotec is deffentily different then a srt4 motor
Just get a sc kit going and be happy. Decend power, fun and reliable ��
Old Oct 9, 2014 | 07:48 PM
user 72239's Avatar
No OP, it wont fit.
You would waste a ton of money making it fit, also the td04 on the SRT4 is tiny. You would be better off buying a Supercharger kit, or building a k04 turbo. Theres a how to on here for 2.2
Old Oct 9, 2014 | 07:59 PM
no_ss's Avatar
No OP, it wont fit. You would waste a ton of money making it fit, also the td04 on the SRT4 is tiny. You would be better off buying a Supercharger kit, or building a k04 turbo. Theres a how to on here for 2.2
does zzp have forged rods and Pistons for the 2.2? I wanna be able to run more than 5psi
Old Oct 9, 2014 | 08:05 PM
user 72239's Avatar
They do. you can run more than 5 psi on the 2.2. but its pretty much how good your tuner is.
Old Oct 9, 2014 | 08:16 PM
no_ss's Avatar
it said on zzp that they don't recommend putting over 5psi on the stock 2.2 so im not gonna put that kind of stress on the stock engine but if I'm replacing the rods and Pistons I could run close to 10 hopefully. Idk. I can only hope. Not looking to be the fastest. I just want to have a decently fast car, I like the way the cobalt drives as well so it would be a plus to have it turbo'd.
Old Oct 9, 2014 | 08:23 PM
user 72239's Avatar
Is that for the k04 turbo? or the bigger Borg Warner turbos?
Theres a difference in flow. I would agree you do not want to run more boost than 5 with a s252 or s256.
Old Oct 9, 2014 | 08:29 PM
no_ss's Avatar
Is that for the k04 turbo? or the bigger Borg Warner turbos? Theres a difference in flow. I would agree you do not want to run more boost than 5 with a s252 or s256.
the k04. Idk if my car could even handle a big turbo lol.
Old Oct 9, 2014 | 08:31 PM
LNFTX's Avatar
More people need to understand this
I raced a civic the other day said he had a 60 trim at 6 lbs I told him that I had a much smaller turbo running 14psi he said I should win. I did but it was hilarious to watch I would get out in front hear his **** start to boost see him pulling for like 2 seconds he would shift then fall back 40-110 had 3 cars
Op its more about the tune and the size of the turbo there have been people on hear with over 300hp reliably and just recently a guy put down closer to 350 your tuner is probably the most important part
Old Oct 9, 2014 | 08:37 PM
no_ss's Avatar
Originally Posted by LNFTX
More people need to understand this I raced a civic the other day said he had a 60 trim at 6 lbs I told him that I had a much smaller turbo running 14psi he said I should win. I did but it was hilarious to watch I would get out in front hear his **** start to boost see him pulling for like 2 seconds he would shift then fall back 40-110 had 3 cars Op its more about the tune and the size of the turbo there have been people on hear with over 300hp reliably and just recently a guy put down closer to 350 your tuner is probably the most important part
I would have to find a tuner in my area. Don't know anyone in the car scene really due to cops breaking up all the car meets I've been to
Old Oct 9, 2014 | 08:55 PM
This is going to be a get out the popcorn thread
Old Oct 9, 2014 | 08:56 PM
Joe09SS's Avatar
^^ Lol bill always got a good input
Old Oct 9, 2014 | 08:59 PM
I call them as I see them ^
Old Oct 9, 2014 | 09:49 PM
Bill don't be bullshittin'. My man has been 'round da block a few times.
Old Oct 9, 2014 | 09:52 PM
user 72239's Avatar
Well you can do more with the k04.
Old Oct 9, 2014 | 09:57 PM
Who? the OP?
Old Oct 9, 2014 | 10:05 PM
I think may have confused you good sir. Mr Bill I love your sense of humor and you sound like you like to enjoy life and have a good time.
Old Oct 9, 2014 | 10:48 PM
I try, and this is a fun site to be part of
