Upgrading Ignition
Old Jan 6, 2010 | 06:45 PM
Rodimus_Prime's Avatar
No cobalts have ever used a distributor and you dont need to use one even if you choose to run the msd
Old Jan 6, 2010 | 07:35 PM
06cobaltindallas's Avatar
i understand that, but msd makes the dis2 and 4 in a distributorless set up as well, so i was hoping to use the dis2 distributorless model. only issue im seeing is that to do that id have to use a crank trigger i believe since the factory crank (58x) uses the hall effect. would that not be correct?
Old Jan 6, 2010 | 08:14 PM
HunterKiller89's Avatar
go check with maven...he'll have definite answers and specific sugestions
Old Jan 6, 2010 | 08:52 PM
Jn2's Avatar
Jn2
Originally Posted by Rodimus_Prime
on a 07 coil on plug theres not really a benefit to running an msd unless your over about 17-18psi
however on the 02-06 2.2 setup the stock ignition really blows
that the amount of boost i push on my 06 2.2 :p 16-17 during the day, 17-19 @night when its colder
Old Jan 7, 2010 | 01:46 PM
DIS2 would be for the 2.2 02-06, the DIS4 would be for any coil on plug setup
as far as either setup you do not need a distributor
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
HEATON
Oct 16, 2015 07:21 PM
dieGone
Oct 1, 2015 06:27 PM
OPCrer
Sep 27, 2015 08:11 PM
