Upgrading internals
Old Feb 16, 2011 | 12:30 AM
redcobalt07's Avatar
Are the ones from crateenginedepot.com a good deal?
Old Feb 16, 2011 | 06:04 PM
kxrida2000's Avatar
Ecotec Crank Shaft Bearing Kit 12591092 - Crate Engine Depot
and
Ecotec Rod Bearing Kit 12591093 - Crate Engine Depot
order them bad boys
Old Feb 16, 2011 | 10:38 PM
Thanks kxrida. Think you could help me put these in someday?
Old Feb 16, 2011 | 10:41 PM
Glowbalt's Avatar
yup, this thread..lol
Old Feb 16, 2011 | 10:44 PM
haha i figured it out eventually
Old Feb 16, 2011 | 11:03 PM
So rod and crank bearings, what other seals and things need replaced while its all apart? Or what should be replaced.
Old Feb 16, 2011 | 11:24 PM
Also valve springs, and valves. What other head things should I upgrade?
Old Feb 17, 2011 | 12:43 PM
kxrida2000's Avatar
i would get a new main seal...also for the head i think u will be fine with just springs...and where are u from lol? it says maryland but ya i could help with everything but doing the valve springs cause i dont have the right valve spring compressor for it cause our ecotec head is goofy...u can get that done at a machine shop cheap though.
Old Feb 17, 2011 | 01:12 PM
I'm at school in western PA right now. But I might as well do valves and valve springs while its all apart right? And what is the main seal? Is that the one for the valve cover?
Old Feb 17, 2011 | 01:16 PM
PsychoCam's Avatar
main seal is the seal behind the crank pully for ur crank
jared are u going stock bore? and what compression u doing?
Old Feb 17, 2011 | 01:25 PM
  #36
yes stock bore 8:9:1 and ttr has some insane shipping speeds. Ordered yesterday afternoon and they are already here. WOW
Old Feb 17, 2011 | 04:19 PM
  #37
TurboTechRacing's Avatar
Yes fast shipping we dont mess around
Old Feb 17, 2011 | 10:47 PM
  #38
So rod bearings, crank bearings, main seal, valve cover gasket. Any other seals or things like that I should replace?
Old Feb 18, 2011 | 09:29 AM
  #39
stenguyen1's Avatar
head gasket. and you wanna order your oem parts from gmpartsdirect.com they are way cheaper than crate engine depot.
Old Feb 18, 2011 | 11:06 AM
  #40
conerboner's Avatar
What are you going to do for fuel Jared?
Old Feb 18, 2011 | 12:15 PM
  #41
Yeah I got the cometic head gasket. But parts like the valve seals, timing cover seal, valve cover gasket? All those parts I should go to gmpartsdirect?
Well I planning on sticking with the stock fuel pump and the 42's I have in now. Do you think I'd need to upgrade any of that?
Last edited by redcobalt07; Feb 18, 2011 at 12:15 PM. Reason: Automerged Doublepost
Old Feb 18, 2011 | 12:17 PM
  #42
stenguyen1's Avatar
yea. that is what i did and you can email them for part numbers if you not really sure what they are. plus they can verify if it fits your car by your vin number.
Old Feb 18, 2011 | 12:20 PM
  #43
Well you can check out all the parts from CED and they come with the numbers. I just wanna be sure I have a complete list of what parts to replace while the motor is torn apart. Like what all gaskets and seals. I just don't wanna miss anything.
Old Feb 19, 2011 | 03:04 PM
  #44
Also what do you think the going rate is for a shop to install all these parts?
Old Feb 19, 2011 | 05:05 PM
  #45
conerboner's Avatar
more than the parts cost.
Old Feb 19, 2011 | 06:17 PM
  #46
damn like what am I looking at?
Old Feb 21, 2011 | 01:15 PM
  #47
also does anyone have a list of all the miscellaneous parts that should be replaced while the motor is torn apart such as gaskets, seals, etc.
Old Feb 21, 2011 | 01:19 PM
  #48
PsychoCam's Avatar
Jared I started pricing out all the parts to do a motor build.
I am over 2 grand and still adding parts up and that does not include any machine work or shipping costs.
If u are serious about doing this dont have a shop do the work, pay someone local to do the install and just have a machine shop do the work we are not able to.
You are going to need the block honed and crank knife edged. Also the head ported and polished if u want to do head work.
I cannot remember what yr you are but if ur an 05-06 I highly recommend getting sleves and having them pressed in.
If you are an 07+ you wont really need sleves for the power your looking for.
Old Feb 21, 2011 | 01:39 PM
  #49
What all parts are you replacing? And a machine shop would be need for the valves and stuff right? And i'm not looking to do the port and polish and all that stuff. Just strengthening the internals. Send me a facebook message with your parts lists.
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
HEATON
Oct 16, 2015 07:21 PM
dieGone
Oct 1, 2015 06:27 PM
OPCrer
Sep 27, 2015 08:11 PM
