Vaccum Lines/Boost Gauge
Old Mar 21, 2008 | 12:37 AM
Cobalt(312)'s Avatar
This is gonna sound like a stupid question but where should i tap the t-fitting into my vacuum lines on the 2.2, if at all possible can someone include pictures or a brief description would help alot.
Thanks
Last edited by Cobalt(312); Mar 21, 2008 at 12:37 AM. Reason: Automerged Doublepost
Old Mar 21, 2008 | 12:38 AM
HackAbuse's Avatar
Why are you putting a boost gauge on a N/A car?
Old Mar 21, 2008 | 12:39 AM
BLAZIN07SS's Avatar
I'm too JDM for you
for a boost gauge? from your sig you dont look boosted though...
Old Mar 21, 2008 | 12:46 AM
i'm getting everything in order for me to do the swap
i'm doing baby steps and then once the summer roles around the cash flow will pick up
Last edited by Cobalt(312); Mar 21, 2008 at 12:46 AM. Reason: Automerged Doublepost
Old Mar 21, 2008 | 12:57 AM
outtamymind's Avatar
well if you put a boost gauge in your car when its not boosted you will get no reading what so ever. so personally i would wait until you get the charger
Old Mar 21, 2008 | 01:05 AM
ItalianJoe1's Avatar
Well, if it shows vacuum, it will still read that, just will stop at 0psi when hes at WOT. Good for measuring fuel economy. Used to be standard on old cars, for tuning reasons.
Thanks
Look for any small vac line coming off the intake manifold, anything after the throttle body. Just cut it, insert the T, and attach your line to the gauge. Be sure everything seals correctly when it goes back together and you'll be fine. Good luck with the boost mission.
Last edited by ItalianJoe1; Mar 21, 2008 at 01:05 AM. Reason: Automerged Doublepost
huh ya i was always told it wasn't. and thats an interesting tidbit of info about the older cars.
Old Mar 21, 2008 | 01:10 AM
Sure, its just a manifold pressure gauge, if the car is in vacuum it will show that. If there is boost and the gauge has the range, it will show it. Vacuum becomes an issue for carb tuning, it is a great indicator of fuel economy, and it matters when you start to build up an engine radical cams can cause enough of a vacuum loss to cause problems with brake boosters and such.
Old Mar 21, 2008 | 01:14 AM
well i certainly didn't know that.
Old Mar 21, 2008 | 10:45 AM
IonNinja's Avatar
brake booster
theres also a line going into the intake manifold that you could tap into
Old Mar 21, 2008 | 11:15 AM
BIG-DAVE's Avatar
i tapped into the one coming of the intake manifold ...
Old Mar 21, 2008 | 12:31 PM
Thanks guys, yeah i just want to do all the preparation before the install.
Old Mar 22, 2008 | 12:43 AM
IanWilson2007's Avatar
well what about the stock ss boost gauge isent that just some wires and thats it or does it have a hose input
Old Mar 22, 2008 | 01:18 AM
the stock ss/sc boost gauge reads from the ecm which is why people have put the mechanical boost gauges in as they tend to me more accurate
Old Mar 22, 2008 | 03:34 PM
so theres no way to make it work
Old Mar 22, 2008 | 05:27 PM
You could use a stock SS/SC boost gauge, but it would be way too much work, many things would have to be changed. Just use a mechanical gauge tapped into a vac line somewhere, much easeier and probably more accurate.
Old Mar 22, 2008 | 11:22 PM
well what if i buy a cheap boost gauge and swap the faces and lighting i think that will work
Old Mar 23, 2008 | 12:21 AM
It could. Just get an autometer that matches up close with the stock ones or something.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Jan 12, 2016 12:01 AM
ineedacobaltss
Nov 7, 2015 02:25 PM
z28addiction
Sep 28, 2015 12:03 AM
Sep 27, 2015 08:53 PM
