vibrant hdr/dp no gasket?
yeah idk but i ended up getting a call from them at 7pm the other night asking me if i still wanted to order a header and dp but i had already ordered the vibrant setup and btw i would much rather have to big than to small.
Nothing against you, I found this on the MangaFlow website..
"To reduce additional backpressure, the OEM exhaust tubing can be replaced with madrel-bent tubing of the same size or one size up from the OEM. As a general rule, you can enlarge the pipe diameter of your OEM exhaust system by 1/4- to 1/2-inch to increase your horsepower. However, any additional increase in pipe diameter is likely to decrease your performance; specifically, low end torque.
Bigger is not always better."
On a cat-back, a bit bigger won't hurt AS bad.. But the primaries on an exhaust manifold are just a little more important.
Just my 2˘
Just my 2˘
Just my 2˘
Just my 2˘
You wouldn't think it makes a big difference.. It does!
A bolted 2.2L does not need primaries that big.
Clear Image > Vibrant. That's just my opinion.
I am reusing my stock gasket and have no leaks with it so I'll just stick with this until it starts leaking. I'll probably end up rebuilding my engine or just sending it into jbody so the vibrant will eventually be fine for my engine.
Turbo Johnny
Feb 21, 2019 09:41 AM
Sep 28, 2015 12:51 PM
Macgyver2484
Sep 2, 2015 05:44 PM
