walbro 255 fuel pump
Old Nov 23, 2010 | 12:43 AM
BlackCobalt707's Avatar
anyone know if they make a direct fit walbro fuel pump for the cobalt or do i gotta get a universal one and make it work?
Old Nov 23, 2010 | 09:42 AM
Spanky's Monkey's Avatar
the pump fits in that black canister in the full tank to full be fine. i can't figure out how to get my extra one apart but i got time.
Old Nov 23, 2010 | 10:13 AM
im a little lost with wat you said spanky
Old Nov 23, 2010 | 10:54 AM
if you look at zzp's site they have an image or 2 of the cobalt fuel pump removed. this get-up looks nothing like the walbro pics we've all seen on the net. the fuel pump for the cobalt is housed in a canister that has the fuel level sender attached to it. to replace the pump you pull the canister apart to do so.
Old Nov 23, 2010 | 11:14 AM
oooooooooooooooh
Old Nov 23, 2010 | 11:26 AM
WSFrazier's Avatar
The canister needs dremeled slightly to fit. Also, the harness will be different, but a set of quick disconnects at any parts store fit on the Walbro's.
This for a 2005 LSJ, though. I run the GSS342 I believe.
Old Nov 23, 2010 | 11:47 AM
thats the model i was lookin at. ill prolly order it this friday if i cant get a interceptor gauge
Walbro 255LPH High Pressure Fuel Pump GSS342: No Limit Motorsport
Old Nov 23, 2010 | 11:51 AM
WSFrazier's Avatar
You sure it's a pump you need? A 1:1 boost/vac reference fuel system would probably be better for you.
Old Nov 23, 2010 | 11:58 AM
i got the zzp one but it leaks at the regulator right now....
Old Nov 23, 2010 | 12:00 PM
well, ever since i gutted my cat and changed my intercooler piping ive been running lean. i talked to vince about it and this is what he said in the email
"What I am seeing is pretty typical of a fuel pump issue - fuel ratio is OK
for a second or so, then it takes a nose dive - there's no corresponding
drop in MAF signal, though, so it's not a MAF sensor issue."
i just have no way of checking my fuel pressue at wot to see if its dropping. also my car starts leaning out when i go past half throttle.
Old Nov 23, 2010 | 12:03 PM
inj? what size?
Old Nov 23, 2010 | 12:04 PM
WSFrazier's Avatar
Sounds like a pump. I had similar issues when I switched to E85. I would assume the 2.2 Cobalt's have an even smaller pump as well.
Old Nov 23, 2010 | 12:05 PM
i got 60s. i was startin to think i over worked my pump wit those big ass injectors lol
Old Nov 23, 2010 | 12:06 PM
thats wat i was figuring. i just wanna find a direct replacement pump lol. i wish these pump were accessible from under the rear seat like it was in my civic lol
Old Nov 23, 2010 | 12:08 PM
WSFrazier's Avatar
Dropping the tank isn't bad. Just sucks if it isn't empty.
It's an easy install. Very little dremeling is needed. Plus, if that Walbro comes with the Pigtail/Harness, you won't need quick disconnects.
Old Nov 23, 2010 | 12:13 PM
yeah, it is easy to drop the tank. i did mine at around an 1/8th a tank with hand tools. i have th lsj pump at the moment.
Old Nov 23, 2010 | 12:15 PM
ive been keeping about a 1/8 tank in it just in case lol. im ordering a fuel pump as i type this
Old Nov 23, 2010 | 12:19 PM
shes ordered and should hopefully be here in 2 days...
Old Nov 23, 2010 | 12:31 PM
you gotta do a how to when you get it.
Old Nov 23, 2010 | 12:36 PM
Tundraboarder666's Avatar
Agreed!
Old Nov 23, 2010 | 01:11 PM
i gotts figure out how to do it myself lol. ill make a attempt on it tho
Old Nov 23, 2010 | 01:14 PM
Drive down here and I'll help you lol
Old Nov 23, 2010 | 01:16 PM
lol. i cant even go pass half throttld without leanin out. i was drivin on the highway like a old grandpa the other day. im actually tryin to get stationed in tucson
Old Nov 23, 2010 | 10:09 PM
lwpmoon's Avatar
I've thought about changing the pump but it seems to be holding up fine I'm on 80's and I'm running a bit rich at 23 PSI. GM is weird...
Old Nov 23, 2010 | 10:47 PM
lucky **** lol
