walbro 255 fuel pump
Old Nov 24, 2010 | 11:18 AM
Tundraboarder666's Avatar
Originally Posted by lwpmoon
I've thought about changing the pump but it seems to be holding up fine I'm on 80's and I'm running a bit rich at 23 PSI. GM is weird...
Ill be doing that soon too. Just need to find a intake manifold thats not stupid expensive.
Old Nov 24, 2010 | 07:20 PM
BlackCobalt707's Avatar
ive been after a intake manifold too. maaaaaan, ****** fedex came by with my fuel pump 5 minutes after i leave for work
Old Nov 24, 2010 | 08:03 PM
Yeah I've been looking at seeing if a LNF manifold will work or the saab 9-3, or the new buick regal or cruze manifolds etc.
I've only seen 3 aftermarket ones Hahn Racecraft - Automotive Turbosystems
RDFABS - Stainless aned Performance Specialists
Vulcan Turbo, LLC -- Welcome --
Old Nov 25, 2010 | 10:09 AM
all expensive as **** lol
Old Nov 25, 2010 | 10:55 AM
07cobaltguy's Avatar
the saab manifold will work on our motors. and the TB is still in the stock location. probably best bang for your buck.
Old Nov 25, 2010 | 02:24 PM
joshc.'s Avatar
AmmFab sheet metal intake manifold as well, I wouldn't order from Vulcan ever.
Old Nov 25, 2010 | 08:55 PM
Spanky's Monkey's Avatar
vulcan isn't even an option as they no longer off their product. they say they are redesigning it so it actually fits......
Old Nov 25, 2010 | 09:45 PM
*crosses vulcan off the list*
Hmm I'm gonna have to look into the saab one, especially if it doesn't require customizing anything.
Old Nov 25, 2010 | 09:59 PM
06_ion2's Avatar
My vulcan isnt too bad. im on the stock pump still, going to try 22psi this spring on it.
Old Nov 25, 2010 | 10:29 PM
I'm on my 3rd stock pump lol. stupid things keep goin out on me, all have been warrantied though!
Old Nov 25, 2010 | 11:00 PM
  #36
and i'm sure you know you're one of the lucky ones.
Old Nov 25, 2010 | 11:04 PM
  #37
06_ion2's Avatar
Only thing is it touches the coolant hose. other that that it looks great, its just a pain to install with no fittings or hardware. Made atleast 8-10 trips to the store before i finaly was happy with it.
What things did people have wrong besides powdercoat?
Old Nov 25, 2010 | 11:05 PM
  #38
yal are gonna hate me but i got my fuel tank off this afternoon and forgot to start a how too lol
my walbro comes in tomorrow and i gotta figure out how to wire the bitch up. ill try and make a how to on it and back track a little
Old Nov 26, 2010 | 12:12 AM
  #39
Super!
Old Nov 26, 2010 | 01:46 AM
  #40
lol. i was in the moment. i got my garage nice and clean, tools organized, tired out the way, cabinets tossed out and i was feelin good
Old Nov 26, 2010 | 10:53 AM
  #41
we need a how to on the pump swap. if these monkeys can't get the fuel tank off without a how to then they shouldn't be trying to remove it anyway......j/k but it is super easy.
Old Nov 26, 2010 | 11:07 AM
  #42
HEY!
I've never attempted it so I wouldn't know, but I like to be prepared and know what I'm doing before I start doing it. That's pretty much how I've gotten by the last 3 years lol
Old Nov 26, 2010 | 11:08 AM
  #43
lol. the fuel tank is super easy to get off. i can do the how to on the pump swap tho. fedex is coming in sometime today. i really wanna get this **** done so i can see if it works
Old Nov 26, 2010 | 11:14 AM
  #44
HEY!
how to drop a fuel tank on cobalt
1. put vehicle on jack stands or lift rear of vehicle via ramps like i did
2. drop cat back so exhaust sits on rear beam unsupported by hangers
3. drop heat shield to fuel tank by removing 4 bolts and have a friend under to help when the tank comes down
4. using flat head screwdriver loosen up clamp that connects the tank to the hose
5. take off all connecting fuel lines and wires that goes to the tank
6. remove tank from under neath the car and locate the fuel pump and lift up on the tabs that keep the fuel pump secured down by using a flat head screwdriver, when tabs are up twist and carefully remove pump from tank
before doing all this remove to disconnect the negative battery cable and relieve fuel pressure in the tank
Old Nov 26, 2010 | 11:21 AM
  #45
Thanks bud!
Old Nov 26, 2010 | 11:47 AM
  #46
lol yuup
Old Nov 26, 2010 | 08:00 PM
  #47
fuel pump is swapped out
Old Feb 7, 2011 | 12:02 AM
  #48
conerboner's Avatar
and? how hard was it to wire up? I'll probably need one of these if i wanna get 80s and e85
Also on the aftermarket intake manifolds, do they make one where the throttle body is on the other side so I can still use my zzp intercooler?
Old Feb 7, 2011 | 11:01 AM
  #49
it wasnt hard at all. i had to do a little modifyin to make it hook up and fit and its fine.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
no_ss
Oct 18, 2015 11:58 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
roth
Sep 26, 2015 12:16 PM
