wanna build my 2.2 up for more boost!
Old 03-16-2011, 12:36 PM
  #251
kxrida2000's Avatar
ohhhh u said cams hah i thought u meant to turn the crank but ya i had to turn the ex cam a little bit to get it to line up and take the slack out of the chain. just triple check that everything is in time before u put the motor back in and roll the motor over from the crank pulley like 3-4 times to make sure nothing binds..if u feel anything bind then STOP and check it out cause if it does bind 9/10 times its a valve hitting the top of the piston and u will bend it
Old 03-16-2011, 12:53 PM
  #252
conerboner's Avatar
ok so i do have to turn it a little to get it lined up? that makes me feel better lol. I was scared if I did that it was going to snap the chain or something cuz the cam doesn't like to move very far and it goes back to where it was when you release the pressure on it.
Old 03-16-2011, 12:54 PM
  #253
kxrida2000's Avatar
ya it almost feels spring loaded kust turn it put the link in the right spot and then let it so and roll it over like i said and then u shuld be good to go..if u want a 6 pin 2.4 tb i know where u can get one from a local near me.
Old 03-16-2011, 01:00 PM
  #254
conerboner's Avatar
alright thanks for the help i'll let you know about that tb. the balance shafts were almost too easy and then i got to the cams and i was like **** haha. oh well i should have it done by this weekend!
Old 03-16-2011, 01:01 PM
  #255
kxrida2000's Avatar
thats good u should be getting the mani within the next 2-3 days but if not its the same as a 2.2 tune wise so u would still be able to run the car
Old 03-16-2011, 01:13 PM
  #256
conerboner's Avatar
yeah i'm not messing with the boost controller at all i might even take it off and just use the wastegate and try to stay out of boost for 500 miles and then slowly introduce it
Old 03-16-2011, 01:22 PM
  #257
Spanky's Monkey's Avatar
i stayed out of boost for the first 300 or so and introduced it to about an easy 5psi low rpm until 500. i was told if you're running a boosted engine you should break it in on boost. nothing crazy but you want the rings to sit how they would under load on boost not na vac. not sure if it's true or not but it made sense to me.
Old 03-16-2011, 01:29 PM
  #258
conerboner's Avatar
yeah everyone has their own way i guess. i read on some site that you beat the **** out of it right away and some say 500 miles of easy. I saw somewhere that on newer engines if you go up a hill and let off going down and use the engine to slow it down that the rings well be good to go but idk this is my first time and I really don't wanna do it again lol
Old 03-16-2011, 01:35 PM
  #259
i'm with you on that. although i'm already thinking of getting a block and sleeving it. not sure if i want to make this an all out drag car or keeping it my dd. if i stay dd, not going over 350whp. if i track her i'm looking at maxing the s256 out @ 500hp on a sleeved block. tough decision.
Old 03-16-2011, 01:43 PM
  #260
conerboner's Avatar
yeah i might eventually go with sleeves i already have a second car that i drive most of the time anyway. the fiance wants me to make her scion tC fast too lol. and I don't know if there is any options for manual trannies that can handle the powah
Old 03-16-2011, 01:47 PM
  #261
i've seen a few boosted tc's around here. some really sexy ones too. how much power she looking for?
Old 03-16-2011, 01:55 PM
  #262
conerboner's Avatar
Idk she would probably be fine with like 250-300. I think they can handle that with stock internals. Not sure if I would get a kit or piece one together this time. It is a manual tho i taught her how to drive on mine and then she wanted one lol
Old 03-16-2011, 05:45 PM
  #263
Brags's Avatar
You should be fine without sleeves, youre 07 gen II block, with good tune you should be fine
Old 03-16-2011, 05:52 PM
  #264
BlackCobalt707's Avatar
i got a friend who builds and tunes tC's. if you have questions i can ask him.
Old 03-16-2011, 07:26 PM
  #265
yeah, 250 wouldn't be hard on the tc and well within the realms of a good fwd dd. you get past 300 and you're looking at serious summer rubber and a good set of winters to keep your **** safe.
Old 03-16-2011, 10:47 PM
  #266
.380ACP's Avatar
the balt is coming along nicely..
Old 03-16-2011, 10:53 PM
  #267
PsychoCam's Avatar
I am at 251 from my last dyno and it is a good fun dd. I want way more power!
motor build for me I hope sometime soon
Old 03-17-2011, 01:12 AM
  #268
Tundraboarder666's Avatar
Build book says sleeves need to be replaced at 400hp
Old 03-17-2011, 01:42 AM
  #269
o3nisoaso3's Avatar
lol soon to retune? were gonna have to meet up within a month or so n go cruise, hit some backroads ****** hard
Old 03-17-2011, 09:51 AM
  #270
he was talking about his girlfriends scion tc, lol.
Old 03-17-2011, 01:46 PM
  #271
D'oh
Reading>me
Kinda worried I'm gonna need to get sleeves :/
Old 03-17-2011, 11:53 PM
  #272
o3nisoaso3's Avatar
2.2l block has ran 600chp w/ just rods and pistons on a built head. gm uses stock crank and rod bearings until that point also
im not saying to go out and try it. just saying that is the power levels i have always heard and ive been around and building 2.2 ecotecs since jbodys in 02-03
Old 03-18-2011, 02:06 AM
  #273
Jbody ecotecs seem to be much stronger than any of the ecotecs they put into Cobaltss. I know that seems like a stupid concept but it seems to be true with all the people that I know
Old 03-18-2011, 07:22 AM
  #274
conerboner's Avatar
Yeah i really don't plan on going over 375 without sleeves just to be safe and running e85 to help keep the temps down
Old 03-18-2011, 09:45 AM
  #275
i'm torn between e85 or just running a meth kit. i'd prefer e85 but i'm not sure i'll have a beater this coming winter and i'd hate to have to swap back and forth.
Quick Reply: wanna build my 2.2 up for more boost!
