water temp gauge install??
can anyone tell me how you hook up a water temp gauge? i kinda have an idea of what to do but not sure where to put the sending unit.. any help would be great and yes i know that it has water temp in the dic..
yeah i know it needs to go in the head or block just dont really know where. and i dont want to remove the factory sensor cuz that'll make the fan come on every time i turn the car on..
ok.. i kinda thought thats what he meant but wasnt sure.. but i already have all the guages i need so im not gonna get anythin else for now..
bump for install of temp gauge
Last edited by yellowltcoupe22; Mar 16, 2008 at 03:45 PM. Reason: Automerged Doublepost
i would say the best place for oil pressure would be in the oil pan.. maybe im wrong though
well now that i think about it i would be wrong cuz there shouldnt be hardly any pressure in the pan.. you would have to go above the oil pump somewhere..
Last edited by yellowltcoupe22; Mar 16, 2008 at 11:29 PM. Reason: Automerged Doublepost
you could use one of the other plugs in the head for oil pressure, however there is a restrictor going into the head so the pressure there will actually be lower than in the block. it still works for monitering purposes (ie too low, sudden loss of pressure) it just wont be the persay Right pressure.
I have the water temp gauge too waiting install and I am thinking of getting the hose adaptor and going with the top rad hose. Nowhere else it can go. The temp sensor just fucked with my fan and I got pissed off.
the tee fittin might work.. i may try that.. if you put it in the upper radiator then your gonna get lower temps than what its suppose to be cuz the water stops flowin in the upper from time to time cuz of the thermostat..
as far as the "tee" goes, i would leave the stock sender in the same position as it would normally be, and then the gauge sender off of the other part, that way it dosent give the ecu any false readings.
yeah thats what i was thinkin too.. if it makes the ecu think its to hot the fan will stay on alot if not all the time and i dont want that to happen and if it makes it think its cooler than it is then the fan wont even come on like its suppose to and that would let the car run hot.. maybe its not such a good idea to mess with the stock sensor after all... i think imma just try to put the sending unit in the head..
well it can hurt to try both ways and then let us know and do a how to so we all know what works and what dosent. A tee wont be more that a few bucks, if it dont work its not a huge loss.
aight man thanks.. im glad you found out which one it was cuz im tired of the gauge bein in the car but not hooked up. if your not gonna do a how to then i may try to get one done so everyone else will know what to do..
