what compression. 2.2 turbo
Old Sep 27, 2012 | 05:31 PM
klutch814's Avatar
10:1 or 9:1? im a 2.2 turbo. going built and eventualy big turbo once funds are here in the near future. untill then ill be running the k04 at about 22psi.
Old Sep 27, 2012 | 05:57 PM
elecblue06's Avatar
as far as compression low compression isnt a bad idea.. I stuck with stock on my 2.4 however dont run the k04 at 22 psi .. you'll be pushing hot air i wouldnt really go past 18 on it
Old Sep 27, 2012 | 06:02 PM
klutch814's Avatar
yea. im going big turbo after i have funds. what would you recomend. i was thinking stock 10:1
Old Sep 27, 2012 | 06:06 PM
TurboTechRacing's Avatar
I always use low on turbo builds on my ecotec.
Old Sep 27, 2012 | 07:56 PM
bluebalt07's Avatar
It's really up to you. Low compression you are gonna lose some low end power but will be able to run higher boost. Stock compression will give you more low end but you won't be able to run as much boost safely. You will make more power with higher compression if running the same boost as a low compression setup though. Low compression is just a safer way to do it.
Supercharged06SS
Dec 11, 2022 04:47 PM
maliki778
Oct 1, 2015 07:39 PM
Tupp
Sep 30, 2015 08:18 PM
Dylan Johnson
Sep 30, 2015 08:57 AM
