You disconnect/cut the wire from the MAF sensor and connect it to the TMAP sensor instead, leaving the wire from the MAF disconnected. You leave the rest of wire leading to MAF disconnected. I'd recommend using electrical tape (liquid tape works well) to keep moisture from corroding the unused wire leading to the MAF in case you revert to stock ever.
Thank you sir, that's what I thought, just wasn't 100% sure.
