wiring in the t-map to maf
Old Jun 15, 2017 | 05:43 PM
Stoney Lawson's Avatar
Hey guys, need some help in understanding something
When splicing in from the t-map pigtal, am I completely severing the connections from the other sensor
Like do I splicein to the wire, or do I cut the wire then splice the connections together, it's not very specific..
I would assume leaving the connection whole would skew the signal
Old Jun 15, 2017 | 06:07 PM
LsCobalt07's Avatar
You disconnect/cut the wire from the MAF sensor and connect it to the TMAP sensor instead, leaving the wire from the MAF disconnected. You leave the rest of wire leading to MAF disconnected. I'd recommend using electrical tape (liquid tape works well) to keep moisture from corroding the unused wire leading to the MAF in case you revert to stock ever.
Old Jun 15, 2017 | 06:09 PM
Thank you sir, that's what I thought, just wasn't 100% sure.
I was going to pull the pin out in it's entirety
