XTC Redesigned Header
Old Sep 20, 2007 | 06:41 PM
Pacific Cobalt
Guest
Posts: n/a
Just got an email from Kenny at Cobalt Addiction.
The new redesigned header will be out in 3 weeks it's going to fit the 2.2 perfectly.
I should be getting around 165 WHP after this header and my XTC Downpipe goes on.
Wait for my DYNO results in about a month.
Old Sep 20, 2007 | 06:44 PM
XM15's Avatar
I think 165whp is a little optimistic. I would expect closer to 150whp if I were you.
By the way, what kind of header is it? Shorty, midlength, longtube?
g5mike's Avatar
Iam assuming its good for all models?
Old Sep 20, 2007 | 06:45 PM
JRelly's Avatar
yes i agree your numbers are very optimistic
Old Sep 20, 2007 | 06:48 PM
shawn672's Avatar
Wait...I thought XTC was working on a header for the 2.2 w/ SAI?
Old Sep 20, 2007 | 07:58 PM
mkulrey13's Avatar
ive been told 3 weeks for the past year. ive given up with them for the most part...
Old Sep 20, 2007 | 10:00 PM
shawn672's Avatar
every week they keep telling you just 3 more weeks? LOL
Old Sep 20, 2007 | 10:24 PM
Pacific Cobalt
Guest
Posts: n/a
Didn't Crate engine depot dyno 151.69 WHP with only GMPP SRI, GMPP Catback and 2.4 intake manifold Kit.
I have all that so adding an XTC Header/XTX 2.5 Downpipe shoud give me 5-10 more HP
Old Sep 20, 2007 | 10:34 PM
shawn672's Avatar
no, you hit a wall at 152whp, thats what everyone else has reported, dunno if i believe it. they said the ECU or PCM basically throttle the gas
some guy dyno'd 152, but on a SS/SC header that was ported, a dp, and something else, and got nearly the same dyno sheet
edit: again like i said, im not too sure if i believe it, b/c how come when people use n2o, they're getting the exact number that their size shot should add.
IE. IF you obtained 80whp from a 75shot on a similar 4cyl, then ppl with cobalts are dynoing with that extra 80whp, but how come the computer isnt throttling and limiting the gas then??
Old Sep 20, 2007 | 10:49 PM
Pacific Cobalt
Guest
Posts: n/a
Talking
You might be right I didnt specify if it's for SAI cobalts
Anyone tried the SCDYNE or ZZP header I need advice cause I have only seen bad reviews so far mostly about fitment issues, rusting, warping.
Old Sep 20, 2007 | 11:02 PM
shawn672's Avatar
i've heard the ZZP header is supposed to be good stuff
emailing XTC right now to get more info
Old Sep 20, 2007 | 11:07 PM
wdsoccer's Avatar
ive been waiting for a year in october, the companyt thats making it for Cobalt addiction keeps telling them 2 more weeks. he said i will be the first to know that its out since ive been waiting for about a year
Old Sep 21, 2007 | 01:25 AM
IonNinja's Avatar
it doesn't have a choice, it doesn't control the nitrous or fuel...the jets do. the only thing it can do at that point is pull timing which you should do anyway under that type of shot.
Old Sep 21, 2007 | 10:34 AM
shawn672's Avatar
ya but why would the computer cut back on fuel if its making 152+whp, but not do the same thing with n2o or a super/turbo charger?
You would think if this is true, the whole 152 wall, then if you strapped a turbocharger to it, it would try to fight the effects and lower your total hp...
Old Sep 21, 2007 | 12:54 PM
IonNinja's Avatar
the ECU doesn't control fuel on a wet nitrous kit
also the limiting factor is the motor itself...at this time it can only move so much air that opening up everything possible wont benefit you any if you can only move x amount of air at a given RPM.
to overcome this you need a cam with more lift and duration to allow for more air.
with a turbo/supercharger you are cramming in compressed air so it can take advantage of the larger exhaust and intake. Also at that point your stock injectors can't even support F/I because you are moving more air then you can provide fuel for so you can't cut back on already maxed out injectors.
Old Sep 21, 2007 | 03:22 PM
shawn672's Avatar
do you do think that the 2.2 has a "152 wall"?
Old Sep 21, 2007 | 03:44 PM
Brandon97Z's Avatar
Its not a "152" wall since thats just merely a number spit out by a dyno, could be 135 on another or 165 on a another. Its more of a cfm wall. The motor can only pull in so much air, like stated above cams will help by allowing the motor to bring in more air. Tuning is playing a big part too as your allowing the engine to breath better but no fuel is being added.
Old Sep 21, 2007 | 04:41 PM
IonNinja's Avatar
i'm sure you could get more power out of the motor alone just from increasing the timing a little bit.
but it pretty much comes down to needing a way to tune no matter which route you're looking to go...
Old Sep 21, 2007 | 05:12 PM
Novajoe's Avatar
we need more than just a way to tune. We need a way to raise the stock rev limiter.
Without a higher rev limit to take advantage of more aggressive cams the only ways to pull more power out of the motor is to raise the compression and add supporting mods that put more power to the ground
Old Sep 21, 2007 | 05:47 PM
Brandon97Z's Avatar
With mose tuning devices they allow you to raise the limiter. But it will all depend on the cam grind.
Old Sep 21, 2007 | 06:06 PM
Novajoe's Avatar
not with our piggybacks. You need to eliminate the factory fuel cut. And that's just not possible with a piggyback system.
Old Sep 21, 2007 | 06:27 PM
YellowLT's Avatar
I only Made 138 with all my stuff.
Old Sep 21, 2007 | 06:50 PM
Novajoe's Avatar
no 2 cars are alike... also all you really have for engine performance is I/H/E
Old Sep 21, 2007 | 10:04 PM
Pacific Cobalt
Guest
Posts: n/a
Good Point I agree that there is only so much air you can get into the engine. If only there was a tune for the 2.2 I would add a comp. Cam and the Stock SS fuel Injectors.
Come On SCT We need your HELP
goaliemo
Sep 28, 2015 01:37 PM
z28addiction
Sep 28, 2015 12:03 AM
budah93
Sep 15, 2015 07:23 AM
hacadacalopolis
Sep 8, 2015 11:42 PM
