yellows back. in the game
so i finaly got my trans yesterday at 5.00 and at 11:00 i was driving my mean little girl again i have some cool pics for ya to see its pics of whats busted on my trans and what my clutch looks like. my stage 3 clutch and alumium flywheel took a beating but all is good..
im at work right now but ill post my pics when i gat my friend over to show my how
sorry havent had time for the pics and vids. but it looks like im pullin the trans again it makes noise when i let off the gas and it shutters.. im priety sure the trans is fine its the clutch thats bad its a rotational sound when i gas it or let off like the flywheel is comming off or the presher plate is moving away from the flywheel. even thow it pulls great. so i have it down to a pat now it only takes 3 1/2 hrs to do theres alot of parts that dont need to be removed to do this. but ill post for every one on the out come
i have to say its a rocket with the cold weather
i had to use stock belt with the stage 2 pully and all i did was bore the mounting holes on the stock tb to go on the m62 snout then ported to match... by making the holes bigger it alowed for the bolts to line up then i used washers under the bolt heads and a piece of flat 1/4 in aluminum plate to make sure the tb sealed up nice...
well i pulled my trans again. to see if my throw out bearing was bad and replaced it with a new clutch and preasher plate and billet flywheel....there was nouthing wrong with those parts.. so now i have a extra clutch and asembly.. turns out the trans is getting ready to throw its bearings...so this will be trans # 4 . i wish there was a stronger manual trans for this dam car... im thinking about changeng my crank so i can use the mu3 trans but i dont think my new clutch will work on it....
