Yet another question on the pacesetter header...
Old Feb 12, 2006 | 12:59 PM
dnbguy86's Avatar
Im seriously about to call turbotech and order it, but im just curious if any one has already purchased it and what were the benfits if any ? Does anyone know if the header already comes with a drilled bung for the 02 ?
Old Feb 12, 2006 | 01:07 PM
TurboTechRacing's Avatar
The header has the o2 sensor boss already in the header. Direct bolt up for the sensor. We have had them in stock for about 1 week now and we have sold 2 painted and 2 ceramic already. Just takes time for the customers to get the header installed. On the 2.2L you will see about 5-9 HP increase.
Ceramic is the way to go, as the painted will not stay black, the paint flakes off. Ceramic will stay show quality for years to come.
Old Feb 12, 2006 | 02:33 PM
IonNinja's Avatar
what about longevity? how long do you think the painted header will last? you can't even see the header really so show quality shouldn't matter. I would be more concerned with rust and how the material lasts.
Old Feb 12, 2006 | 02:55 PM
The ceramic obviously will out last the life of the painted. If you have a ton of road salt and never was the underside of the car, it will be a lot harder on the painted version. As the Ceramic will take a bit more abuse.
Old Feb 14, 2006 | 12:01 AM
dnbguy86's Avatar
So i've read you must cut the header pipe right at the cat, and have someone weld on the extension and then you can bolt up the header. Is this true, because its sounds like a lot of work ....
Old Feb 14, 2006 | 12:27 PM
97cavie24ls's Avatar
yes its true
also you want the extension put on the header first , then put the cat up , make sure you have clearence around the pipe , then tack weld it , pull the cat and extension down weld it
then reinstall it
Old Feb 23, 2006 | 04:06 PM
primetime's Avatar
Smile
i have the ceramic,i love the looks the power everthing...but yes it was a bitch getting them on they bolt up great and very easy only prob is the flang the trick is bolt up the flange first and then weld the cat see i had a leake because when it got welded on it didnt weld strait so the flanges didnt match up right so i had a little leak.......i didnt notice any bottom end grunt but the top is amazing i could be doing 75-80 on the freeway shift to fourth and pull like crazy...get the ceramic they help disperse heat better and they look good
Old Feb 23, 2006 | 05:06 PM
niknyce's Avatar
So this isnt direct bolt up? Thats poopie.
Old Feb 23, 2006 | 05:09 PM
WadaSty51's Avatar
im getting my ceramic pacesetter installed on the 9th along with my sportlines......ill have a video up of it later that week so u can SEE and HEAR the difference. btw, i have a secret weapon n a magnaflow full cat exhaust so i will DEFINATLY be the FASTEST 2.2 out there........im jp
Old Feb 23, 2006 | 05:21 PM
IonNinja's Avatar
this picture made it all the more clear of how this thing is installed
you cut the stock downpipe right where this extension piece ends and you weld it to the rest of your exhaust. so basically, install header...run open header to exhaust shop, $20 to weld piping and done.
OR
if you don't cut that piece like shown above, it gets smaller at the end and you stick it inside your stock piping and clamp it down...making it a direct bolt on. All you would have to do is possibly trim your stock downpipe a little bit so u can stick the piping inside.
Although I would rather weld it because then you don't have to worry about leaks.
Hope this helps...
Old Feb 23, 2006 | 10:23 PM
SlateFox's Avatar
nice.. im gonna get it... after my rims and suspension though =)
brandon04
Oct 21, 2015 07:04 AM
patooyee
Oct 15, 2015 05:11 PM
Iceberg
Sep 29, 2015 12:33 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
