Yet another SS/SC header question thread
Ok, I tried asking in the How-To section's thread for adding on a GM header but didn't get an answer so I may as well ask here.
Is it possible to reuse the stock gaskets from the 2005-2006 2.2 headers/DPs when putting on a SS/SC header/dp, or do they need to be replaced with new ones to function correctly?
The stock gasket is the same between the two models, so that's not a problem.
However, it's a gasket, so you should probably replace it anyway. It's what, $20? Get a new one.
The reason your question wasn't answered in the How-to section is because you are not supposed to ask questions in the How-to section. It says it right in that section. All threads there get moderated to make sure they are in How-to guides and not questions.
z28addiction
Sep 28, 2015 12:03 AM
