2.2L LAP Performance Tech 2.2L LAP Performance Tech (2009+) 155 hp EcoTec with 150 lb-ft of torque
180hp N/A help
Old Jan 7, 2012 | 09:58 PM
redcobalt07's Avatar
180 hp n/a is still a highly optimistic goal for a 2.2
Old Jan 8, 2012 | 01:41 PM
souchak2112's Avatar
I thought the LE5 and the LAP intake manifolds are the same size.
Old Jan 9, 2012 | 10:03 AM
cleanxfe's Avatar
lap and le5 have same top end
Old Feb 4, 2012 | 09:53 AM
Mr.09cobalt's Avatar
so ur saying u only have 156hp when u come stock with 155 u gain 1hp from ut tb full exhaust and intake?
Old Feb 4, 2012 | 09:59 AM
i thoguht zzp sells cams from the 2.2
Old Feb 4, 2012 | 10:00 AM
i believe these would work wouldnt they - LE5 Performance Camshafts #04-02-00691
Old Feb 4, 2012 | 03:12 PM
cleanxfe's Avatar
156whp, stock is 155hp at the crank
Old Feb 4, 2012 | 05:05 PM
bratboy90's Avatar
My buddy threw an LSJ TB on it, and it gained some good HP.
BTW, the Injen intake is crap. The TB connector is way to restrictive, you will need to replace it with a Mandrel bent 90degree.
Old Feb 4, 2012 | 05:34 PM
06_cobalt's Avatar
LAP's have cam sensors so no it will not work. No one sells cams for the LAP.
Old Feb 20, 2012 | 02:50 AM
Izyo's Avatar
Thanks you everyone for your help. For now I have decided to go for the goal of 170hp overall. I think a gain of 15hp is reachable for me. So what else would I need other than full exhaust and intake to get to my goal.
Old Feb 20, 2012 | 02:56 AM
  #36
07blackg5's Avatar
Slobodan Milošević
i made 161 whp/ 148 tq untuned at zzp
short ram intake, 2.4 intake manifold, and full exhaust
Old Feb 20, 2012 | 11:19 AM
  #37
BankerBalt's Avatar
You just need to get a cam sensor pressed on the intake cam i believe
Old Feb 20, 2012 | 11:28 AM
  #38
LS6Rally's Avatar
IIRC LE5's have cam sensors
Old Feb 20, 2012 | 11:53 AM
  #39
BlueBalt1113's Avatar
dark child- how did you only run a 14.5 i ran a 14.7 with just intake header exhaust tune and 2.4tb and intake mani with my interior????
Old Feb 20, 2012 | 12:01 PM
  #40
cranemaster's Avatar
I vote supercharger
Old Feb 20, 2012 | 02:19 PM
  #41
07blackg5's Avatar
Slobodan Milošević
14.7 in an na 2.2? on dr's or street tires?
Old Feb 20, 2012 | 03:57 PM
  #42
DarkChild's Avatar
Probably should have mentioned that wasn't me. I just found it on Youtube and thought I would post it in this thread. I personally think 180hp can be reached.
Old Feb 20, 2012 | 04:05 PM
  #43
chevygirl2006's Avatar
My friends 2.2 g5 ran a 14.3. All motor. He's a 5 speed. Header intake tune catback stage 2 clutch light weight flywheel and pully
Old Feb 20, 2012 | 05:23 PM
  #44
LS6Rally's Avatar
^ stripped interior too? Seems like a fast time
Old Feb 20, 2012 | 05:31 PM
  #45
No. He didn't take anything out
Old Feb 20, 2012 | 05:40 PM
  #46
07blackg5's Avatar
Slobodan Milošević
are you talking about the guy with the ion 2.2? if you are he stripped EVERYTHING, including the side mirrors, vinyl over the grills. and he had drag radials when he ran 14.7. he now has cams and the lightweight flywheel and whatever else and is in the low 14's
and hes from somewhere in french canada
Old Feb 20, 2012 | 05:58 PM
  #47
Um no I'm talking about one of my best friends with a 2.2 orange g5. He lives in Dallas...he ran a 14.3 with the mods I listed.
Old Feb 20, 2012 | 11:44 PM
  #48
lowered tire pressure on proxies and we all have to remember depending on the sea level of the track your times will change
Old Feb 21, 2012 | 10:02 AM
  #49
jbenso4's Avatar
Timeslip? Very hard to beleive. I was fully bolted and tuned and could only squeak a 14.90 on street tires before i supercharged.
Old Feb 21, 2012 | 10:27 AM
  #50
Yes he has like 4 time slips with the exact same times. And the number on his car. He ran a 14.8 and then he put his stage 2 clutch and lightweight flywheel on and he went back and ran 14.3.
