2.2L LAP Performance Tech 2.2L LAP Performance Tech (2009+) 155 hp EcoTec with 150 lb-ft of torque
2.2L super charger swap
Old Aug 24, 2023 | 07:33 PM
kvirgo's Avatar
i have a ‘09 Pontiac G5 Base Model, and im interested in making my car faster & have more power but idk where to start or what direction to look in to get started. I’ve read some things about kits but idk which kit & what to all get. If any can help it’ll be very thankful
Old Aug 26, 2023 | 05:10 PM
chevygirl2006's Avatar
This is a complete parts list to supercharged your 2.2/2.4. 2005-2006 2.2 l61 CAN NOT be tuned.
Supercharger+gasket $150-$250
4x supercharger bolts(can get them from crateenginedepot.com) or get a hex style bolt from the parts store. $10-$50
Intake manifold+gasket $100-$200
Intake manifold bracket $20-$30
Heat exchanger $100-$200
Ic pump+plug $40-$100
Ic pump bracket $40-$50
Lsj idler pulley $15-$30
Alternator bracket $20-$50
Lsj tensioner(zzp adjustable optional for smaller pulley) $15-$120
Lsj belt or stage 2 belt for smaller pulley
Intake. $40-$70
Lsj throttle body $40-$70
Lsj throttle body adapter harness from zzp 06-07 need 8-8 pin 08+ need 6-8 $35-$50
Lsj intake or lsj aftermarket intake $50-$250
Maf extension harness from zzp $30
Ev6 injectors or ev1 injectors+ev1 harness $100-200
LTR6IX-11 Spark plugs $40
2x 60mm shoulder bolts part#0154419 $10
5x 10mm shoulder bolts part#0154418 $15
7 washers for bolts
Those are for the intake manifold. Ordered from fastenal. Can't use lsj bolts. We need m6. Or tap for m8x1.25
Lsj map sensor and plug (will need to be rewired to work) or your stock map sensor will work but you won't be able to read iat2(which is very important to read)
Lsj windshield washer tank(yours will have to be deleted)
Hoses for heat exchanger
Lsj upper radiator hose
Random clamps
Tune $250-$350
Extras
Wideband $180ish
Pillar pod $80ish
Boost gauge $varies
Old Aug 29, 2023 | 06:11 PM
Monieg5gt's Avatar
I'm actually in the process of supercharging my 07 Pontiac G5 GT. Like Chevygirl said you gotta get a fair amount of parts but it can be done cheaply if you piece it together. Just take your time. I still got a few more things to get before I finally get my car done.
06_ion2
Mar 16, 2014 07:41 PM
2005 Slobalt
Aug 24, 2012 09:41 AM
bratboy90
Dec 21, 2011 12:42 AM
Greased
Nov 9, 2007 05:42 PM
