2.2L LAP Performance Tech 2.2L LAP Performance Tech (2009+) 155 hp EcoTec with 150 lb-ft of torque
2.4 throttle body install
Old 09-20-2011, 08:49 AM
  #76
rcarr0327's Avatar
where does someone go to acquire the 2.4 mani + TB...
p.s. i would just get a tune to start out with :P
Old 09-20-2011, 08:54 AM
  #77
padlock's Avatar
either find someone selling them used on here (which is the cheapest option).. or buy them new from crateenginedepot.com
Old 09-20-2011, 09:24 AM
  #78
drumrush's Avatar
I'm selling an 8 pin 2.4 throttle body
Old 09-20-2011, 12:26 PM
  #79
rcarr0327's Avatar
this it? Ecotec HO Intake Manifold Kit 2.2MMGF - Crate Engine Depot
@drumrush: 60 shipped right? ill have to think about it. i think my first step is to get a new wideband sensor since mine blew out... just dont wanna blow 80 bucks to have that one blow :/ ill definitely keep ur TB in mind though
Old 09-20-2011, 03:35 PM
  #80
cleanxfe's Avatar
rcarr0327 your tb has a 6 pin connector and you already have 2.4 intake manifold, get a 2008 2.4l Le5 tb thats all you need! just installed mine today love it runs with no codes!!!!
Old 09-21-2011, 12:51 PM
  #81
rcarr0327's Avatar
ok well i'm running boost idk about you so i would rather get a tune. So i already of the 2.4 manifold just need to pick up a 6 pin 2.4 TB?
Old 09-21-2011, 01:21 PM
  #82
cleanxfe's Avatar
yeah but it has to be 2008 for some retarted reason gm only made that tb for one year then they changed it to what it is now, 2005-2007 is a 8pin for the LE5
Old 09-21-2011, 02:21 PM
  #83
09xfebalt's Avatar
Check my fuel trims with a tech 2 gm wants them ą 10% mine is at 1% so well within specs for a heads up before tune
Old 09-21-2011, 03:26 PM
  #84
cleanxfe's Avatar
what tune are you getting, im getting hp dyno tuned on sat
Old 09-21-2011, 09:03 PM
  #85
09xfebalt's Avatar
Trifecta
Old 10-12-2011, 02:22 AM
  #86
Clifton's Avatar
Wait, So I can actually install a 2.4 TB (long as it's a 2008) over my LAP w/o a tune. Whats the part number?
Old 10-13-2011, 11:48 AM
  #87
Mr.09cobalt's Avatar
what tb can i use sence i have a 09 lap....or can i get the throttle body spacer and it will work or what?
Old 10-14-2011, 03:26 AM
  #88
Validater's Avatar
Just installed my 2.4 throttle body, have AFR gauge, without a tune it runs normal to the stock TB, and does have noticeable gains. well worth the money for me. now just need to save up for a bloody exhaust.
Old 10-14-2011, 09:14 AM
  #89
rcarr0327's Avatar
2008, 2.4L throttle body. only year they made a 6pin and thats whats the 09's need. idk about any other model tho i assume all LAP's
Old 10-27-2011, 10:23 PM
  #90
cobalt2010's Avatar
hmm this is making me consider doing on my car. i have access to a tech 2 so i can do the same
Old 10-27-2011, 10:53 PM
  #91
nhanson's Avatar
i recommend the LSJ...
BUT the 2.4 TB would be easier if you found the correct # of pins
Old 10-29-2011, 09:19 AM
  #92
09xfebalt's Avatar
I am a firm believer in the only REAL difference in LE5 and LAP power ratings is everything gm did to de-tune the 2.2. If cams and TB were the same im sure they would be almost the same in power output. I mean who needs a TB thats almost 3/8 bigger for .2 of a liter more displacement?
Old 10-29-2011, 10:22 AM
  #93
nhanson's Avatar
Going from 2.2 to 2.4 is only a couple mm. But the lsj is a huge upgrade
Old 10-29-2011, 10:47 AM
  #94
09xfebalt's Avatar
Originally Posted by 09xfebalt
Put 250 miles on car yesterday no cel and got 35 mpg according to dic which was 2 mpg better than what it normally is for what its worth
its was around 10MM I will get exact sometime.
Old 10-31-2011, 09:37 PM
  #95
09xfebalt's Avatar
stock 2.2 58mm le5 65mm
Old 04-16-2012, 05:39 PM
  #96
2009CobaltLT's Avatar
Would the 6 pin 2.4 tb from an 07 essentially bolt on without rewire? Obviously I'd need a tune
Old 04-27-2012, 01:20 AM
  #97
Crav3's Avatar
ok so a 2.4 TB of an 08 cobalt will work on my 2.2 without a tune? i have an 09 2.2 g5
Old 04-27-2012, 01:20 PM
  #98
rcarr0327's Avatar
yea and if u need to clarify anything just look at the number of pins. should be 6 pin
Old 05-02-2012, 01:19 AM
  #99
Clifton's Avatar
I just noticed this for quite sometime. After I let off the gas or stop b4 shift to P, the rpm would stick at about 2k for a sec before lower to idle. I think the 2.4 tb has something to do with it. I also have a 2.5 catted dp and 2.5 custom exhaust. Any thoughts?
Old 05-06-2012, 06:49 PM
  #100
noorj's Avatar
I haven't read through the whole thread so I'm not sure if it was already said but:
OP- Raise your limiter, if you have full bolt-ons I'm positive you will continue to make power up top. Ask me how I know.
Quick Reply: 2.4 throttle body install
